Originally posted by Steve Walter Canon FD. IT APPEARS THAT THE RING CAN TURN IN EITHER DIRECTION. i SAW SOMETHING THAT SAID THE WHITE NUMBERS ARE FOR CANON.
Usually. When the the lens is properly mounted to the mount, a pin is lined up that set the aperture scale to one side or the other. If it turns though both sets of scales most likely the pin wasn't positioned correctly when the lens and mount were paired. The mount has a white dot and a pin is to be positioned at that dot (if I remember correctly). I do have this lens and I'd need to pull it out and take a look to be sure.
