Originally posted by UncleVanya I’m happy the op found a d500 and is going to be able to enjoy the camera. The Sony options that exist that work well with bird in flight are very expensive and I have no doubt the d500 is a great bargain comparatively. While Nikon F mount lenses are mostly discontinued the availability remains high. I look forward to seeing some results.
UncleVanya, sure Nikon, Canon, and Sony have very expensive bodies in both mirrorless and mirrored formats. These are all full frame models however and my thought was that I already have the K1 ii for that.
After Ian gave some really great advice in my last post about what to do and where to go, I started looking at the D500 more seriously. Originally I had planned to look at a used D4S but somethings were pointed out in favor of the APS-C sensor size.
After all, the D500 is a Pro camera in a 'compact' body with the same AF system and sharing many other features of the D5.
When it comes down to use case I originally bought my K1 for astro and landscape work. The AstroTracer functionality is great! At this time I didn't know or understand about more in depth astro equipment or anything about processes involved etc... as a result the K1 has taught me a lot and it is really is a powerful imaging tool.
If I start talking about camera brands like ZWO and Moravian Instruments, we are getting into non-linear photography that is more about science then simplistically put, going somewhere getting inspired and shooting a subject. It really is a world in its own right as there many wavelengths that standard cameras are unable to capture. One reason is the IR and UV cut filters installed directly on the sensors. Sensor design is also important as in CMOS or CCD, monochrome or beyer matrix (eg. color).
More information can be found here:
Multiwavelength Astronomy - Introduction https://en.wikipedia.org/wiki/Astronomical_spectroscopy
Using these specialist tools, one can easily splash hundreds of thousands of $'s, for example the 10Micron tracking mounts start at anywhere between $12k and 15k.
Yep the good ol' K1 taught me about this and so much more!! :-D
Of course what I did not consider before the purchase of the K1 was wildlife or any type of action at all. That came about recently after seeing images and postings from friends around the world who have interests in birds and other types of animal. Even at the macro scale things are pretty interesting!
Initially, sure I wanted to work with the K1. I tried hard and asked a lot of questions. It is an area which I have no experience or knowledge in. Stumbling upon a few macro videos on Youtube for example, it became apparent that I was using an incorrect technique to start with. Hold camera then adjust focus ring until subject is in focus.... try doing that on a bee that hops from flower to flower... aint happening :-/
But** as shown, find a focus setting that works for your insect, first observe and analyze the behavior. 1:1 mode may not be suitable for skittish bugs, so instead try 1:14 or 1.25 and move the camera in and out until in-focus. Sure the hit rate increased in leaps and bounds though I still need way more practice.
The extra reach of APS-C and lower weight will definitely help in many areas.
The main point though as after creating my previous thread I had thoroughly researched what I needed for a system built around the D500. I had selected and chosen the lenses already and defined use-cases for each. It simply boiled down to only needing 4 lenses as the K1 would take over with the rest.
After not finding the D500 available new, sure that completely threw me off and trying to find equivalent lenses for my now defined lens / usecase set became a headache.
For a mirrorless system for example, no one has an 18-300mm walkabout lens. It is not obvious yet if any of the Laowa macro lenses will work on the APS-C R system of Canon though FF is supported. Adapters are needed for the Sigma.
Too much over complexity at the moment with that. Once things mature then sure there maybe these lenses available but for now the list of compromises was too great.
That's how I was thinking about things in any case.... think I'll go and create a 500px account now and start playing around there. Hopefully over time it will grow with nice in-focus images :-)
