Long story short, I thought I'd take advantage of some haze the other night & try to take some pics of visible beams of a rotating light beacon at the airport. Similar to what a lot of people do with light houses (closest lighthouse is about 7 hours away, so this will have to do.) Anyway, finally got everything to stack & merge after several problems (PS doesn't like to stack for some reason for me) but there's tons of artifacts in the final image: rings & what looks like a moiré pattern. No optical filters were used which should rule out newton's rings. There were no artifacts in the individual images, or even if you look at the layers merged together in photoshop, only in the final image after all layers are merged. So what are they? I'm wondering if the circles are atmospheric phenomenon similar to moon/sun dogs that are so faint they aren't visible in the individual shots (I'll have to look again at the individual pics later tonight after work closer to see if there is any trace of halos). Someone suggested these might be a result of the bulb/array itself in the beacon, being LED instead of tungsten. That theory makes a little sense as the camera for whatever reason used electronic shutter instead of mechanical as I usually have it set to. This is about 20 shots stacked, 1/4", f/2, ISO 4000 (beams weren't very visible at lower ISO). My theory is they're some kind of artifacts from the stacking. My computer often does strange things when stacking & merging in Photoshop (skewed or flipped images, smears). Need to try this on my laptop to see if I get consistent results. Of the two shots, one is a single image (one of several) and the other is the final. Other than stacking, it's uncorrected & AWB was used.
