I understand that there were disappointment regarding the D40X, as it didn't bring much more to the table than the already crippled D40.
And as some had chosen Nikon because they didn’t fancy Canon, I see that people might want to check what else is out there.
But I thought that generally Nikon had good compatibility ?
Originally posted by HGMonaro Sometimes, the bank account only has so many $$$ in it... What takes a better picture, a Pentax in your hand or a D300 in the shop window?
I was somewhat in the OP's position (although I didn't have a Nikon dSLR to confuse the issue even more), and the D200 body I needed (at the time) was over $1000 more than the K10D and 16-45 lens. I still have my Nikkors but after experimenting with a Nikon-Pentax convertor (contains crappy glass element to fix focusing issues) and then weighing up a D300 vs K7, I bought the K7 as although I could, I was not willing to spend the extra $$$ required for some zoom's. I can't see how adding Ai/Ai-S compatability to D80/D90 level of cameras is going to hurt sales of D200/D300 cameras. I'm just about ready to sell the Nikkors and buy suitable Pentax replacements as although I'd be happy to manual focus, stop down metering or meter by trial is pushing the friendship too far!
Ai/Ai-S compatability, does that mean manual lenses ?
I thought D80 and D90 had in camera motor ?
Originally posted by B Grace The camera that takes the best picture at any given time is the one you own and the Nikon shooter already had a D40. In addition to my K200D, I share a D40x with my wife. It's a very capable camera in the hands of someone knowing his or her way around with a basic camera...much like the FM2N the Nikon shooter also has. If I already had, say, the 28/2.8, 50/1.4 and 105/2.5 Nikkors, all MF AI-s, I'd find a way to step up to the D300 or even a used D200. I do have three primes for the D40x including a AF60/2.8D micro so I've even considered buying an "ancient" D100.
The 28/1.4 is another lens that Nikon ought to reissue
Edit :
I found the info on some reviews :
"Perhaps the biggest negative on the D40 is that it doesn't have an internal focus drive motor and hence no mechanical focus drive pin, instead it only has CPU contacts which means it can only Auto Focus with AF-S and AF-I lenses (those with built-in focus motors). Indeed our 'standard' lens the Nikkor 50 mm F1.8D (and the F1.4D) are manual focus only on the D40."
"As with the D40 the D40X doesn't have an built-in focus drive motor which means it can auto focus only with lenses which have their own drive motor (AF-S and AF-I lenses).
No lens motor in body means non-AF-S/AF-I lenses are manual focus only"
