Yes, I have used and like the Holga. Some common mods were to:
- Cut (or dremmel) the film plane mask to go from 6x4.5 to 6x6 cm.
- Spray paint the inside of the camera flat black (reduce light bouncing). Use a piece of tape to cover the hole to the lens before starting.
- Fix the f-stop lever. I think this can be done by gluing a nut (or washer) to the lever with the right size hole.
- Use a piece of black tape over the red window and only lift it to advance the frame.
- Use a rubber band around the body to secure the back (prevent it from opening).
- Use a piece of scotch tape on the inside film plane surface (one on each side). This fixed the film scratches I got when advancing the frame.
One of my favorite film and dev combos for this camera was Ilford Delta 3200 with PMK. This will get you 800 ISO with some nice negatives. So I could shoot in overcast light and shadow without a problem. 320-400 ISO is better for bright or partly cloudy days. I also bought a pinhole holga from this place:
holga
They also have other mods including the plastic holga lens on a Pentax body cap. Looks interesting and should not be too difficult to make one yourself. I have some old shots with the holga here:
Rockefeller Skating Rink: Photo by Photographer Philippe Tempel - photo.net Guardian of the City: Photo by Photographer Philippe Tempel - photo.net
Have fun with your new camera. ;-) One of my favorite holga photographers is Craig Sterling:
Italy | CRAIG STERLING PHOTOGRAPHY
Most of his shots in Venice, Italy with slight vignetting were done with a holga. Amazing what kind if images you can get out of a few plastic parts...
