Originally posted by Digitalis "help to reduce the CA."
A curved sensor wouldn't affect CA in the slightest. Yes, the lenses in compact cameras are bad, compared to SLR designs..but because they are so small the tolerances have to be extremely high to produce a quality product...and that just isn't possible when P&S cameras are experiencing a reduction in market size due to the increase of EVIL cameras, and low priced entry level DSLR cameras.
The problem with these small lenses is not so much production related (tolerances etc.). There is basic constraint: The resolution of a lens is limited by its diameter - nothing else. If the diameter of the lens gets smaller, the resolution goes down unavoidably (Rayleigh-criterion). There is no circumvention.
Now, combining a lens with a low resolution with a small sensor with high pixel density is a bad idea, because the resolving power will not make use of the pixel count. That is, why most 12MP p&s cameras will not show more detail, than a 7 or 8MP cam.
Then ofcourse add the other detrimental side-effects of small sensors (limited dynamic range, higher noise), and the whole compact package is destined to lack IQ. It is more astonishing, that these cameras produce acceptable to good images (printed int the standard small sizes) at all!
Ben
