06-18-2010, 11:40 PM   #1
dws1117's Avatar
Nikon D3000 or D5000?
I've made the decision to go back (i'll be 39 in Sept.) to school to get my BFA in photography. I love my Pentax gear and have no intentions of getting rid of it the school will only let me use Canon or Nikon. I've decided on Nikon because that is what they are using at the school and they have tons of Nikon glass, flashes, and other accessories for student use. They have a supply kit that can be purchased that includes a D3000. I've broken down the cost of the kit with and without the camera and the difference is almost $800 US. While I have no problem with the D3000, I do have a problem paying that much for that model.
Which of these two should I choose? I've handled both and both feel fine. I've even put together packages with both at B&H and Adorama and the cost is negligible. I would prefer the D90 because it is more comfortable in my hand but it's just out of my budget.
Does anyone have any help or advice? Thank you.
06-19-2010, 06:40 AM   #2
If you have access to legacy glass, you NEED at least the D90 as the 3000 and 5000 have no in-body focus motors.
You'll be spending more on overcoming your glass limitations than just jumping up to the D90 body.
Having said that, wait... D90 replacement is imminent. You'll be able to get a D90 cheaper then.
06-19-2010, 06:40 AM   #3
Oldschool's Avatar
Have you thought about buying used? You can probably save some $$$.
06-19-2010, 07:12 AM   #4
QuoteOriginally posted by Unsinkable II Quote
+1 on D90 for too many reasons to list. Focus motor is a good start.
woof!
06-19-2010, 07:45 AM   #5
Wayne,
Since you already have some nice Pentax equipment I would get some used Nikon equipment as Oldshool said. You can get an used D70 and be able to use all Nikon glass.
Even if you decide to go Nikon way later you could sell the D70 for almost the same price you payed for it.
Regards,
Luis
06-20-2010, 08:53 PM   #6
try out KEH for a used body - they have 2 d70s right now under $300, or a d200 at $600 (d50 and d80 are also listed available). Ask around, best place to buy used online!
06-21-2010, 07:09 PM   #7
Clarkey's Avatar
+1 on a D90 or a D80. D80 avail refurb from adorama.
I would wait for a D90. It's replacement really is imminent from all accounts.
06-21-2010, 07:16 PM   #8
Aristophanes's Avatar
QuoteOriginally posted by dws1117 Quote
D5000 for low-light, high-ISO. D3000 for cost-savings.
D70 is a good call if you want refurb really cheap. Make sure you get a warranty and set aside another $300 if the camera is a dud and you need another body real quick.
06-21-2010, 07:38 PM   #9
Direct to the point, go with the D5000. First, though, verify the Nikon gear available at the school consists of AF-S DX lenses otherwise you'll be shooting manual focus only on the D5000 (the minimum Nikon camera I'd consider). And if the school's Nikkors are manual focus, silver grooved band around the barrel lenses you'll only have "meter after the shot" metering even with the D90. Finally, the Nikon flashes must be of the SB400 thru SB900 series otherwise you lose auto-TTL control with the current Nikon DSLRs. I traded away a wonderful SB50DX only because of that reason.
Tangential questions: Why would the school care if you shoot Pentax gear and how would they know? Is it possible they recommend Nikanon only so the students' choices are easy?
06-22-2010, 08:15 PM   #10
alexeyga's Avatar
There are so many used D90s on the market, and prices are so low in US, i woudn't even consider anything else... The built-in AF motor alone is worth getting one... Though, depending on your high-iso needs, a used D200 might be an even more attractive option...
06-22-2010, 08:57 PM   #11
What kind of Nazi school is this?!?!
06-23-2010, 10:33 PM   #12
dws1117's Avatar
Thanks. Pulled the trigger on the D90 which is the one I really wanted. Came across a little extra. I even get to keep my Pentax gear.
06-29-2010, 02:22 AM   #13
I'm lost
What kinda of school tells you that only nikon or canon must be used.
06-29-2010, 02:30 AM   #14
Probably they have only canikon accesories and manuals
06-29-2010, 04:42 AM   #15
QuoteOriginally posted by JACOBY Quote
Most likely they have legacy Canikon glass and do coordinated FOV topical shoots.
cost, d3000, kit, nikon, school
Pentax K-x over Nikon D5000? cm9210 Pentax DSLR Discussion 11 06-17-2010 11:38 PM
k20d vs nikon d5000? quiksilver Pentax DSLR Discussion 16 05-17-2010 10:52 AM
Pentax K-x vs Nikon D3000: ISO 100meters Pentax News and Rumors 8 01-15-2010 10:48 AM
Lumolabs: Nikon D700 vs. D5000 vs. Pentax K-x, Dynamic range and noise falconeye Pentax News and Rumors 12 12-18-2009 05:34 AM
Nikon D5000 Leaked. PNTXFTW12 Non-Pentax Cameras: Canon, Nikon, etc. 16 04-15-2009 10:17 AM
All times are GMT -7. The time now is 02:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
