Originally posted by pingflood Well, it really does not affect IQ in any way. What it does is exactly the same as any other camera when using an aspect ratio that is not native to the sensor; just crops it a bit.
You can look at it as either neat, the camera lets me have similar MP count and angle of view thanks to this
or
why the heck won't they let you use the entire sensor instead of forcing you to always crop in some way?
If you are interested in the fancier point and shoots, do not forget about the Samsung EX-1 / TL-500. Or Ricoh GR-D III though that one is a bit of an odd bird.
Well, it seems to me it doesn't "just crop it" -- that's the whole point. As for using the entire sensor, it
is using it -- but for the purpose of maintaining quality in all ratios. I believe the Lumix sensor is slightly larger than the S95's -- perhaps in order to accommodate the cropping?
Anyway, I'm sure you're right -- for my purposes the IQ difference if any is probably negligible. For all I know, the S95 may be better in other ways. If I do succumb to temptation though, I'd probably go for the Lumix for the sake of the 24mm and slightly faster (across the range) lens, and the
much better battery capacity.
Thanks for mentioning the other two cameras -- the Ricoh is odd, and interesting. The close-focused pics I've seen from it look fantastic.
