Originally posted by tuco I really don't see how camera shake is an issue turning off/on the camera. You should always have a leader and trailing footage of your scene so you can edit transitions. The shake of turning off/on won't be in your shot final edit.
I've edited this response after some work on the problem today.
The tools provided with the camera only allow you to make a simple DVD with very minor editing ability. You can remove the jump at the beginning and end of every clip. However, the supplied software doesn't have anything like the capabilities of Sony Movie Studio Platinum which I normally use. I appear to have a major issue in the form of Sony Movie Studio because it looks like the only plugin I can use for the AVCHD.264 codec is the built in one, and from what I understand, Sanyo have their own proprietary version of H.264. It also looks like only the bundled software may be able to use the Sanyo codec, and the codec doesn't seem to be loaded for other software to use like for example the Fraunhofer MP3 codec is.
I wouldn't even mind so much if you could save the simple edited clips as a file but the only option is to burn them to disk directly.
It's just not a comfortable arrangement using your thumb to start and stop the video with a button on the top right hand side of the back of the camera. A trigger on the front would have made a lot more sense given the "pistol grip" arrangement for holding it. None of the buttons on the camera are easy to operate.
Thus far, I haven't been able to record any video with the camera that I am particularly happy with unless it's viewed on a non-HD TV where the poor resolution and poor encoding is hidden by the poor resolution and interlacing of the TV. I have finally spent another $50 to buy an HDMI cable to connect the camera to the HDTV, and the picture through HDMI is far better than I could get previously using composite video. It appears that the camera's composite video output is poorly scaled. At this point it appears that the only way to get the camera's proper resolution is to play back from the camera itself through HDMI or to make a DVD (or, I hope, blu-ray disk) using the bundled software. I'll do a bit more research on the Sony forums to find out if anyone has figured out a way to get decent quality output from the Sanyo H.264 video.
