Originally posted by montman I feel like when I am shooting at 2.8 on a FF it’s like shooting F2 on a cropped body. !
That's because basically you are. The larger sensor means a smaller DOF at any given aperture than smaller sensor. F8 on a large format camera can give you nice bokeh. F1.9 on a small sensor camera gives you lots of DOF.
The larger sensor is one of the advantages of full frame if you are after bokeh. You can shoot stopped down a bit where the lens usually is a bit sharper compared to a crop factor where you have to have a really good lens and shoot wide open.
I'm totally on board with your thinking and if I end up with full frame someday, this is exactly why. I can always shoot a smaller aperture if I need a larger DOF, but it's harder to go the other way.
Now on the other hand, a larger aperture on a crop will get you the same DOF, but a little more shutter speed, though it might be a wash because on full frame you can up the ISO on stop and make up for the difference in many cases as full frame usually has lower noise.
