43 Rumors | Blog | (FT5) First non blurred E-P3 picture with 12mm lens (+ FT5 Olympus rumor summary)
Seems like they address most major concerns of the EP1
1) Common features of all three new PEN cameras
- Very fast autofocus
- Truepic VI engine
- New Olympus designed sensor
- All three PEN cameras do have AF assist lamp
- Old lenses will focus faster on the new Pen cameras (although not as fast as when using new lenses).
2) Olympus E-P3
- It has the new Olympus “tweaked” 12 Megapixel Sensor
- Truepic VI engine (two processor in one)
- ISO 100 to 12.800
- 1080i 60frs AVCHD or JPEG video
- 35 point autofocus
- OLED touch Display (610k resolution). Sounds like it is almost the same screen used for the Olympus XZ-1.
- pop up live guide
- dual dials
- flash is remote trigger capable, but no free bounce like Olympus E-PL1.
- fastest AF to date for any mirrorless cam (and I have been told that it is considerably faster that the Panasonic GH2!).
- updated art filters
- effects to combine with art filters (like starlight)
- 3D still images
- built-in Eye-Fi support for controlling the Eye-Fi cards (Click here to see the cards on eBay)
- Interchangeable grip. I have been told there are two different grips you can buy (and more will come after).
- Design changes: The top dial is now placed instead of the ON/OFF button of the E-P2. To make room for the built-in flash. There is a video recording button over the AEL button.
- Price somewere between $799 and $899 dollars
3) Olympus E-PL3
- Same sensor and af speed as the E-P3
- no built-in flash (Will have bundled external flash that uses the hotshoe+accessory port)
- tilting LCD screen
- Screen is LCD and not OLED.
- looks EXACTLY like the Olympus XZ-1 (Click here to see that camera)
4) Olympus E-PM1
- It is as small as the Olympus XZ-1
- No tilt screen, no built-in flash
5) 12mm f/2.0 lens
- It’s the very first High Grade lens for Micro Four Thirds and is made in Tatsuno (Japan)
- All metal construction with distance scale. You see the distance scale when you pull the focus ring from autofocus to manual mode.
- Lens size similar to the new Panasonic Leica 25mm f/1.4.
- Filter size 46mm
- Already in production since April and will be in Stock in July.
- Close focusing 20cm (0.67 feet)
- Price around $799
6) 45mm f/1.8 lens
- No macro
- Price around $299
7) New Olympus FL-300R
It works like the Sony’s F20AM (Click here to see the Sony flash on eBay). For example you fold down to turn off.
8 ) New external EVF
- cheap build quality, cheap price (Compared to the current VF-2 viewfinder (around $279.95)).
9) Olympus 14-42mm II R
Same price and optical performance as the current 14-42mm lens but with a much faster autofocus performance.
10) Olympus 40-150mm II R
Same price and optical performance as the current 40-150mm lens but with a much faster autofocus performance
