Originally posted by bimjo True enough, but when I can get a camera and 4 or 5 lenses for the weight of my camera and 1 (maybe 2) lenses it seems a fair tradeoff. The tripod is on top of that. And I could go with a lighter tripod than what I'm schlepping around now.
I'll admit that in the past I've poo-pood using a lcd to frame a shot. But I gotta tell ya, after 2 motorcycle crashes and a near-death illness in the last 4 years it begins to make more sense to me. Especially for low angle shots. Creaky is my new middle name.
You do bring up good points though and I appreciate the input. More to ponder…
K20D : 142 x 101 x 70 mm (5.59 x 3.98 x 2.76"). 800 g (1.76 lb / 28.22 oz) inc. battery.
Kr : 125mm x 97mm x 68mm (4.8 x 3.6 x 2.7 in). With D-LI109 battery: 598g (20.5 oz).
Sony 5N : 110.8 x 62.2 x 38.2 mm (4 3/8 x 2 3/8 x 1 9/16 in.). 269 g (9.5 oz.)
As you can see there is a world of difference between your current camera (K20D) and the Kr and the NEX 5N, but size-wise the Kr to 5N is not so dramatic falling right in the middle (K20 to 5N). In fact it is really only the depth that you would notice and if you slap an adapter on the 5N then this has gone too.
Pentax Lenses : 15/4 7.47 oz (212g), 21/3.2 (5.5 oz./155g) with hood, 35/2.4 (124g/4.4 oz.), 40/2.8 3.2 oz. (90g), 43 Ltd (5.5oz/ g), 70/2.4 4.6 oz. (130g), 50-200 (non WR) (9.2 oz. 262g).
Sony Lenses (5N) (don't forget these are NOT stabilised unless stated (OSS), which adds considerable weight) : Typical adapter 3.9 oz (110g). E to A mount Adapter ($400 !) 7.1oz (200g), E 16mm f/2.8 SEL16F28 (70g / 2.5 oz), Carl Zeiss Sonnar T* E 24mm F1.8 ZA (225g / 8 oz), E 30mm f/3.5 Macro (138g / 4.9 oz), E 50mm F1.8 OSS (202g / 7.3 oz), SEL 1855 18-55mm f/3.5-5.6 (6.84 oz (194 g)), E 55-210mm F4.5-6.3 OSS (12.1 oz (343 g)).
I think you can see quite clearly from the above that the size & weight saving is small without an adapter and this then becomes negligible (as does the size difference) when adding an adapter.
Typical usage Kr + lens : with 15 (810g), with 21 (753g), with 35 (722), with 40 (688g), with 70 (728g), with 50-200 (860g).
Typical usage NEX 5N + lens (add another 110g to 200g if using non-E mount lens with adapter) : 16 (349g), 24 (494g), 30 (407g), 50 (471g), 18-55 (463g), 55-210 (612g).
You pay your money and make your choice but for me a saving of 120g to 450g for my
primary system (and missing out on the extra options of the Kr and wonderful Pentax primes) is just not worth it. I see the 5N/7 as wonderful back-up options though (with an E to PK adapter so I don't have to buy E/A mount lenses), especially if you are comfortable using MF. YMMV !
