ok well as promised here is an update for anyone who is interested.
so if you have a look at the following picture it shows the back of the lens mount
and here is a closer view so you can see the action
so at location marked 1 is the pin that connects to the 'A' connection on the camera - this provides 3.3V from the camera to this pin. My first assumption was that the voltage carried along the track from location 1 to location 2 and then onto 3 where it 3 created the connection to the lens mount - but this turned out to be incorrect. There is a split in the track essentially at location 2 - and i now think that this break in the track is to seperate the Pentax A connection and the Ricoh A connection. (Ricoh pin at location 3)
So what was the problem well if you look at location 2 you can see an extra leaf connection sitting above the main track - this is supposed to be pushed down to make connection to the main track by the little nodule shown in the following photo
it seems that the nodule has worn down (it is only plastic on the aperture ring) to the point that it no longer makes the leaf spring touch the main track.
So the circuit actually works 'A' pin supplying 3.3 volts - runs along the track and when the aperture ring is the A setting the voltage goes through the leaf spring shown (at 2 above) and to the lens mount through the mounting screw that holds that leaf spring in place.
So what do i do to fix it - well i dont have much choice here - i will put a dab of solder between the extra leaf spring (at 2) and make it a permanent connection which means it will always be in auto aperture mode - suits me anyway.
If nothing else i learnt something and i hope someone else does too.
If anyone wants more info let me know and ill be happy to explain further
Adrian
