Originally posted by westmill How good is the focussing on the MD. Is it fast enough to catch some one walking at you for example ? And will it focus in a dimly lit church ?
Great questions, however, I am a manual focus user and I don't use AF for anything - I just checked that it works after I unpacked the camera. I played a bit with it using the Panasonic 14/2.5 lens and it looked fast and precise. I also liked the touch screen as an interface for selecting the focusing point - I think that is one of the great features of the E-M5 - for manual focus it helps me in two ways: I can select the area to zoom in and I can take a shot without pressing the shutter, which helps avoid vibration. After I ensured that the AF works, I removed the AF lens and I strapped on the manual ones that I had ordered with the camera
So I cannot really comment on the performance of the AF in extreme scenarios, but I did read some comments and it sounded like AF-C works best if you set the image mode to vivid - a tip to remember if you try the camera.
Originally posted by westmill And have you tried its flash ability to any extent ? I intend getting either the Fuji or the MD very shortly
At the moment the Fuji is in front I think. Mainly for its fast zoom lens as much as anything. I rather hear from some one with personal use in the field than your average review, so I would be very grateful on your true thoughts
I haven't used the flash - I didn't even fire it once to check if it actually works. It's an add on, similar to what the E-PL3 came with, but a bit different in shape. It looks as useful as a built-in flash on a DSLR, which is to say - not very useful. I much preferred the built in flash of the E-PL2 which I could tilt up, to bounce its light. The E-M5 add-on gets raised a bit like a DSLR flash that pops and that's it - I would only use it as a fill flash on bright days. I keep it in the camera bag, but I doubt I'll mount it often.
I am tempted by the X-E1, but I am now thinking I should wait one more year and see if someone will finally produce a FF MILC. I have tons of FF lenses and only 3 APS-C lenses, 2 of which are the kit zooms.
