Originally posted by savoche Thanks, I will see if I can get something like that.
About Pentax K to MFT adapters:
1) from reading user-reviews several places, it seems that Novoflex adapters, with a stop-down ring, are generally highly regarded. Guess what? They are
EXPENSIVE
2) Adapters sold under the brand name "FotodioX" are good and a fraction the cost, but be sure to get one with a stop-down ring if you need one.
3) The Chinese brand "Klipon" also offers K to MFT adapters, with variable reviews (may indicate poor quality control = there are lemons among the cherries).
REMEMBER: IF you have a manual-focus K-mount lens with an A-M switch on it, that's easier to use than the ring on an adapter. If you have K-mount lenses with click-stop aperture rings (and an "A" setting), obviously you can count clicks or just approximate. Some MFT bodies have a menu selection for constant viewfinder brightness so you can attach a lens and have it stopped down to f8 or f11 all the time and you will still have just as bright a viewfinder/screen image as a lens opened to f1.4. It works on my MFT bodies and focus peaking still functions but may not be as accurate. AND, all of a sudden it's too bad there aren't some high-quality preset lenses still in manufacture Old preset lenses in M42 mount that are good performers: the 8-element 50mm f1,4; the 135mm f3.5 preset, the 200mm f5.6 preset; and some 50mm f2.8 Tessars. There are also quite a variety of Russian-made M42 lenses that at least some Pentaxians think are good, but look for one that is either preset or has an A-M switch.
