Originally posted by UncleVanya My experience is that the Panasonic bodies are easier to use particularly if you are a Pentax user. Olympus menus are not great - though they aren't totally incomprehensible. If this is for Mrs. Unless she is a serious photographer the GM1 is tiny and capable. The wifi setup is a little quirky but workable. The buggers are expensive however.
I use both Oly & Pany bodies. The latter was definitely an easier transition for menus and ergonomics, Small things such as the "ON" switch of the Oly is at top left as on some Canon cameras, whereas the Pany "ON" switch is around the shutter release as on Pentax bodies. Both cameras have deep menus, almost like an NYC yellow pages, but the Pany is definitely easier to navigate than the Oly. The latter has been faulted by many reviewers who have experience with essentially every DSLR made. One would think that Oly would pay attention and make some changes, but perhaps they are fearful of offending long-time Oly users by making too many alterations to a system that brand-loyalists have mastered. BTW: A small thing that I have found annoying. I sometimes press the 4-way with my thumb (right hand) and accidentally change a setting, such as white balance. Did this with my K3 in Africa an wound up with a purple leopard (perhaps not as bad as a purple cow). My Oly EM10 mk ii is especially problematic because of its tiny size*. A good solution on my Canon 7d = there is a sliding switch below the 4-way that locks it. My Pany G9 has a menu option for locking the 4-way, and that can be assigned to one of the function buttons for convenience.
*The Oly EM 10 mk ii is almost too small. I find a better grip, and less tendency to bump the 4-way if I add a grip. The OEM grip is really elegant, just big enough, very light (= mostly plastic), and it's easy to get at the battery & memory card, BUT, you cannot use a quick release in any reasonable way. The RRS grip is a little bigger, heavier (= all aluminum), and it's a bit more difficult to get at the battery & card, but it has a built-in Arca-Swiss type track as well as a 1/4 X 20 spot. So, if you're only going to hand hold, the OEM grip is better. If you're going to use a tripod or monopod, with the OEM grip you'd be limited to a 1/4 X 20 screw, with the RRS grip you could use either a 1/4 X 20 thread or an Arca-Swiss release.
