12-24-2019, 09:32 PM   #2971
Are people adapting K mount and M42 lenses to MFT cameras with good success? Just got a Lumix GH-3 for a good price primarily to get more use out of my Auto 110 lenses. Not played around much but I'm not real happy so far. In my brief trials I feel like it gets noticably off center. I haven't figured out if that's just a issue with the lens itself, having to shoot wide open (but if I could stop it down, it would be sharper) or if it's just that I'm dealing with a narrow DOF from shooting wide open. It's been getting dark here in the evening when I get home from work, so my testing has been limited. Any advise for using these lenses or advice on adapting M and A series lenses? Seems like there are several really cheap K mount to MFT adpaters. Any that are particularly good or ones to avoid.
I like the camera a lot and feel like with a sharp K mount prime, it could be a good pairing.
Thanks,
12-25-2019, 06:20 AM - 1 Like   #2972
QuoteOriginally posted by Lhorn Quote
Thanks,
I have a cheap adapter (all that matters is that it has a ring to control the aperture of the lens, as my DA 50 1.8 doesn't have a manual aperture ring. I'm rather satisfied with the results.
12-25-2019, 07:43 PM   #2973
Since I own a Canon Eos and a lot of adapters for putting weird lenses on that, the first thing I bought was an Eos to MFT adapter with a built-in iris, which gives me compatibility with (deep breath) M42, PK, Olympus OM, Praktica bayonet, Contax/Yashica, Minolta MD, Exakta, long M39 (the early Zenit SLRs), Rolleiflex, Canon FD, Fujifilm X (the 35mm models), Nikon, and probably a couple of others I've forgotten. So it's cost about 12 for the Eos adapter, most of the others are much cheaper than the usual MFT adapters because they're smaller and I think sold in larger quantities, but in this case free because I already own them. The Canon FD, Fujifilm and Minolta MD adapters aren't ideal because they incorporate corrective lenses - I've already ordered a FD to 4/3 adapter because I see a lot of FD lenses, and will probably get a Minolta MD version eventually, I don't see enough fujifilm lenses to worry much about them.
Getting back to the PK adapter, it works well and since it's just a flange there's no reason why it shouldn't, I'd imagine this also applies to the PK to MFT mounts. But the aperture control ring is definitely a good idea for later Pentax lenses that lack manual controls - I have something like it on my Nikon adapter for use with their "G" series lenses that lack manual aperture control, unfortunately there isn't the physical clearance for this with a PK mount on an Eos, so if you're just after this one conversion definitely go for the direct PK to MFT adapter.
12-28-2019, 08:49 PM   #2974
jimr-pdx's Avatar
I use native m43 primes at 7.5/14/20/30mm then shift to Pentax A50/1.7, M100/2.8 and M200/4. I have zooms also (12-40, 45-150, Zuiko 70-300 FT) so I can play versatile or small/fast. The M100/2.8 needs a click or two for best results, but both systems are in-body stabilized (K200, GX7, EM10).
---------- Post added 12-28-19 at 19:56 ----------
Curiously enough my 'standard zoom' is the xiaoYi 12-40 f/3.5-5.6 In my tests with several others it performed comparably and I liked its range. What really sold me was that Oly/Lumix bodies (apparently) do not autocorrect off-brand lenses for distortions - but this lens matches up with the corrected shots! Sure wish it zoomed the Lumix direction, but now I have the 4thirds 70-300 so each zoom makes me think before twisting. Just kidding: I don't think I just twist and act like I meant that result
12-29-2019, 07:19 AM - 1 Like   #2975
WPRESTO's Avatar
Crocodile in a spotlessly clean pool.
DC-G9  Photo
12-29-2019, 07:43 AM   #2976
UncleVanya's Avatar
QuoteOriginally posted by Marcus Rowland Quote
Tried the Lumix G1 for photomicroscopy earlier today, using the fold-out screen to focus etc. My microscope is an oldish medical lab design that has a fairly high vertical tube and eyepiece for cameras, it's almost at eye level so the screen is much better than trying to peer down a normal SLR's viewfinder. I haven't done much in this field in the last ten years or so, and I really need to brush up my technique etc. Results were OK but could be much better - the slide I tried was a bit of an antique, a Victorian sample of whale bone, the picture is at 30x magnification. My set-up for this was a Nikon microscope adapter, with a Nikon to Eos adapter, then an Eos to Micro 4/3 adapter, which is a stack about 8" high on top of the microscope tube, and really doesn't help. I just ordered a basic Micro 4/3 microscope adapter which is about an inch long, I hope that it will be an improvement. I'm also going to get a remote control to reduce vibration.
Meanwhile I need to read up on things like magnifying the viewfinder image to focus, also tweak the microscope lighting etc., I think it's probably going to need a good clean if nothing else. I'll probably post more next year.
Interesting area to explore. I'm looking forward to seeing your efforts.
12-29-2019, 08:53 PM   #2977
jimr-pdx's Avatar
QuoteOriginally posted by jimr-pdx:
The more I look into this topic, the more my head aches
YI states that their M1 does corrections, so I presume that it corrects other brands too? Since TruePic VII (EM1/10) Oly bodies claim to perform the magic with Lumix lenses.. so perhaps the YI 12-40 is corrected in my EM10. But how about Sigma lenses, those reverse-engineering mount specialists: do they conform to the cameras' expectations?
The more I read, the more I see we're all in the same boat. Nearly every post comes from someone who believes they understand it all, but each has a slightly different subtlety that suggests we're not all saying the same thing. I wish these things had an "all corrections off" that I could be certain would do exactly that.
I'm not going to waste a bunch of time testing for variations though, life's too short for that. If someone has a definitive statement on this, I'd like to spend 15 more minutes on the topic and be done!
12-30-2019, 04:52 AM - 1 Like   #2978
WPRESTO's Avatar
I was in a zoo when this picture was taken, but this lizard was free, just living on the premises as squirrels do in American zoos.
DC-G9  Photo
12-30-2019, 09:03 AM - 1 Like   #2979
A funky abstract.
12-30-2019, 07:30 PM   #2980
WPRESTO's Avatar
Pottery, an art installation.
DC-G9  Photo
12-30-2019, 10:39 PM   #2981
UncleVanya's Avatar
QuoteOriginally posted by jimr-pdx Quote
That's very well said Jim. I'd love to see an article that clarified this from official m43 sources.
01-01-2020, 02:21 PM - 1 Like   #2982
Insanely humble
savoche's Avatar
I do have a cheap m42->m43 adapter that seems to work well with the old Taks. It's not something I expect to do a lot as I like them better on the K-1 anyway. If I ever get around to do some video I think the Taks will become more interesting to use on the GX80.
For stills I mostly use the kit 12-32. It's small and works well enough. The GX80 works well enough, too, but small it ain't... I love the tilt screen though! Perfect for use as a waistlevel finder
01-01-2020, 06:01 PM   #2983
WPRESTO's Avatar
Nepalese temple generally called the Peace Pagoda.
DC-G9  Photo
01-02-2020, 12:40 PM - 2 Likes   #2984
Insanely humble
savoche's Avatar
4 pm in mid December. Depressing.
01-03-2020, 09:07 PM   #2985
False color infrared of Carson Mansion, shot with IR converted E-PL1 + Oly 17/1.8:
20mm, aaron, andrew, camera, communities, couple, dec, e-p5, eddie, equiv, filter, flickr, flores, focus, gear, ii, john, lens, lenses, m43, macro, oct, olympus, omd, panasonic, pentax, pm, post, smith, version
comparing adapters for Micro Four Thirds (MFT) rparmar Non-Pentax Cameras: Canon, Nikon, etc. 25 08-09-2011 10:01 PM
Kr/Kx or Micro Four Thirds snowfreak Troubleshooting and Beginner Help 16 07-18-2011 01:12 PM
Leica 25mm f/1.4 for Micro Four Thirds jct us101 Non-Pentax Cameras: Canon, Nikon, etc. 3 06-13-2011 05:46 AM
Pentax seriously considering joining Micro Four Thirds? iht Pentax News and Rumors 2 04-30-2010 11:49 PM
All times are GMT -7. The time now is 06:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
