05-01-2021, 10:38 AM - 2 Likes   #3661
WPRESTO's Avatar
Oly EM10 mkII with Oly 12~45mm f4. No idea what this little plant is called
E-M10MarkII  Photo
05-01-2021, 04:53 PM - 2 Likes   #3662
05-02-2021, 05:26 AM - 2 Likes   #3663
QuoteOriginally posted by Mbaez Quote
The actual focal lenght that you are going to shoot.
This question comes up even with native use of older k mount zooms. The answer varies a lot. As the previous person posted the most effective is setting out exactly to the focal length you use. That’s pretty Time consuming if you are using the zoom with frequent focal length changes. Others have advised to set to the longest or shortest length. Finally some advise to use the middle ground - picking a focal length in between the shortest and longest length. This last seems the most likely to have the least negative impact and most benefits unless you spend most of your time at one end or the other.
Thanks so much for your responses!
I was indeed hoping there was a less cumbersome solution than needing to reset the focal length compensation every time I adjusted the zoom lens.
The solutions you have both suggested are most welcome, and I will put them into use during my next photo walks. I'm particularly interested in trying out the 'middle ground' theory that you suggested, UncleVanya.
In any case, thanks again!
05-02-2021, 06:33 AM - 6 Likes   #3664
WPRESTO's Avatar
Pany GX8. The EXIF says 200mm actual, 400mm FF equivalent so this was taken with a Sigma 150mm macro attached via a Metabones 0.71X Ultra adapter. There is definitely a sense of long-lens compression.
DMC-GX8  Photo
05-02-2021, 07:24 AM - 8 Likes   #3665
QuoteOriginally posted by AgentL Quote
Excellent capture!
Thanks.
Again, with the Oly 100-400:
05-02-2021, 04:38 PM - 4 Likes   #3666
05-03-2021, 05:28 AM - 3 Likes   #3667
WPRESTO's Avatar
Olympus EM19 mk II, Vario-Elmar 100~400mm
E-M10MarkII  Photo
05-03-2021, 03:58 PM   #3668
05-04-2021, 05:28 AM - 1 Like   #3669
WPRESTO's Avatar
tom turkey who's either uncooperative or camera-shy. G9 + Pana-Leica 200mm f2.8
DC-G9  Photo
05-04-2021, 05:40 AM   #3670
Mbaez's Avatar
Same thing happened to me yesterday. Turkeys don't want to help.
QuoteOriginally posted by WPRESTO Quote
05-05-2021, 08:14 PM - 2 Likes   #3671
Olympus OMD EM5 mkII + 7artisans 25/1.8
E-M5MarkII  Photo
05-06-2021, 01:30 PM - 5 Likes   #3672
Infrared with the Oly 17/1.8:
05-06-2021, 02:35 PM - 4 Likes   #3673
Always good to have the 45-200 with me, this was a walk at noon in the local woods and I didn't expect much so the 100-400 stayed at home
05-07-2021, 07:13 AM - 1 Like   #3674
Mbaez's Avatar
Color samples
Lumix G9 + Lumix 45-175
05-07-2021, 08:47 AM   #3675
If anyone is using Flashpoint or Godox flashes/strobes, Adorama has the Flashpoint R2 Pro 2.4GHz Transmitter for Panasonic & Olympus (XPro-O) on sale for $19.95. Doesn't say how long this price will be in effect. See -- https://www.adorama.com/fprrr2proo.html?EmailPrice=T&CategoryID=253685
« Fuji X series club | - »
20mm, aaron, andrew, camera, communities, couple, dec, e-p5, eddie, equiv, filter, flickr, flores, focus, gear, ii, john, lens, lenses, m43, macro, oct, olympus, omd, panasonic, pentax, pm, post, smith, version
comparing adapters for Micro Four Thirds (MFT) rparmar Canon, Nikon, Sony, and Other Camera Brands 25 08-09-2011 10:01 PM
Kr/Kx or Micro Four Thirds snowfreak Troubleshooting and Beginner Help 16 07-18-2011 01:12 PM
Leica 25mm f/1.4 for Micro Four Thirds jct us101 Canon, Nikon, Sony, and Other Camera Brands 3 06-13-2011 05:46 AM
Pentax seriously considering joining Micro Four Thirds? iht Pentax News and Rumors 2 04-30-2010 11:49 PM
All times are GMT -7. The time now is 12:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
