Originally posted by Aegon
Russ, I'm awfully impressed with the ISO 6400 sample. Did you do any significant post processing or is that more or less SOOC?
I cleaned it up in LR4. But not nearly as much as my E-P1 files. These files are very close to my K5 files (definitely better than my K20D files). I'm very happy with the high ISO image quality, and the overall dynamic range, of the images from the OM-D.
I thought I had some more high ISO samples to post, but I just noticed Flickr's not picking up the EXIF from my shots for some reason. I'll see if I can get some more real world examples.
Bottom line, though, is I set the upper range on my Auto ISO to 6400 (per DPR's recommendation) and I don't feel constrained by that at all. I run the same setting on my K5, so that should tell you something.
