Originally posted by excanonfd Originally posted by RioRico: Dare I suggest Nikon? Are cheap M42-F adapters. Your Taks could find a home there.
What about the difference in the register distance, wasn't it yourself who said Nikon is the donor and not the beneficiary?
I searched for Pentax-Nikon adapters a couple days ago and found plenty of cheap (US$3) M42-F adapters on eBay. IFF those adapters are 1mm thinner than standard M42-PK adapters THEN screwmount lenses with narrow-enough bases would reach infinity focus on a Nikon cam.
I haven't actually touched nor tried these adapters, but they COULD work. Here's how: The register difference for Pentax and Exakta is even less, about 0.75mm. I have adapted several Exakta-mount lenses for PK by modifying, not the lens, but the adapter! Glue an M39-M42 ring around the Exakta bayonet blades. Grind off about 0.7mm from the narrow flange of the M42-PK adapter. Thread that on the lens and VOILA! A thin-enough Nikon adapter would behave the same.
For Nikon, there could be a limiting factor: lens base width. I have a number of old M42s with rather narrow bases. These could easily fit into the recessed zone of a thinned adapter. Larger M42s would be too wide, would bump against the camera mount ring, would be subject to loss of infinity focus.
So at this point, I'll say that using Taks on Nikon for other than close work is possible but not proved. I'll accept contributions to conduct the experiment, eh?
EDIT: Even if an M42-F adapter couldn't allow recessed seating, some M42s could still be used, the same as I use various M42s on my K20D with a thick-flange NIF (no-infinity-focus) M42-PK adapter:
* Long teles that normally focus past infinity anyway
* Macros and other close work, and portraits; infinity doesn't matter
* Moderately long teles (200-300mm) where stopped-down DOF will reach infinity
