Fotomagazin has published a front view of the upcoming Nikon D600. The picture is probably synthesized though it is said to be an accurate representation of the actual unit. You can see the entire article
here (in German).
There are also claims that the following updates are 99% accurate::
- Very small and lightweight body
- 16 bit image processing
- Expeed 3 processor
- Maximum video recording: 30 minutes
- Built-in mic
- 19 scene modes
- Magnesium alloy only on top and back only
- Maximum shutter speed of 1/4000
- Shutter life: 150,000 cycles (the D800 is rated for 200,000 cycles)
Previously reported Nikon specs:- 24.7MP full frame sensor
- Weight: 760g (850g with battery and memory cards), the D800 weights 900g
- 3.2" LCD with 921K dot with ambient sensor control
- HDMI output
- Video compression: H264/MPEG-4
- Full HD with 30p, 25p, 24p, HD with 60p, 50p, 30p, 25p
- Viewfinder coverage: 100%
- The Nikon D600 will have built-in AF motor
- The body most probably will be weather sealed
- The D600 will not have built-in GPS
- ISO range: 100-6400 (with Lo-1 ISO 50 and Hi-2 ISO 25,600)
- 39 AF points (with an option of 11 AF points), 9 cross-type AF points
- AF face detection
- Exposure compensation: ±5 EV (same as the D800)
- The D600 will probably use the EN-EL15 rechargeable Li-ion battery
- 5 fps (same as the D700, the D800 has 4fps)
- 2 SD card slots with Eye-fi support
- Build-in retouching images functionality
- Built-in flash with sync speed of 1/250s
- Two user settings: U1 and U2
- Fn button
- Auto DX crop mode
- In-camera RAW editor
- Built in time-lapse functionality
- Build-in HDR
- New external battery grip
- Internal AF motor
The price of the D600 is rumored to be around: $1500 (TBA Sept Photokina 2012)
Images:
Size Comparison with the the D800:
