The D7100 is turning out to be a great camera and for me a very fine addition to my equipment arsenal. When comparing the D7100 to the K5, the D7100 IMHO is just overall quite a bit better - I am really hoping that the new K3 will be up to par with the D7100, although that will be a real challenge for Pentax and really can't see them coming out with anything soon that can compete with this thing unless they pull a miracle out of their a$$. The features packed in the D7100 is incredibly impressive, here is a quick take on what I have seen thus far:
[[ FER: I have well over 110K snaps between 2 K5 bodies and I am about 12K snaps into the D7100 ]]
/******************************************** MY D7100 Pro's VS K5
- First and Foremost, Features!
The features packed into the D7100 are without a doubt extremely impressive and is lightyears ahead of the K5. I won't really go into the features in detail, but to be able to customise the rotational direction of the dials is just one of the many features found in this thing and should give a hint of how flexible and detailed the options are in this body, you can TRULY make this thing yours [customized to your liking].
- Sensor
Obviously, the sensor is a plus. One of the biggest pluses is the post cropping flexibility with these larger mp sensors - I can crop big and still retain large print sizes in excess of 300dpi, this has really helped in my gallery work. Also, one huge area where this sensor trumps the K5's sensor is in detail, especially when using NR - I can see practically no loss in detail when using LR's noise reduction with shots in excess of 4000iso (this is also noted on DPReview's review of this body/sensor). Sharpening is another plus, it seems that this sensor also allows for finer and cleaner sharpening, K5 outputs easily show sharpening artifacts when pushing sharpening to it's max, the D7100 outputs seem to show near zero sharpening artifacts even after pushing sharpening to it's limits with much cleaner edges and contrast transitions.
- AF
Well, really not much to explain here, the AF system is a pro system from the flagship D4, that says enough.
- Size
For me, the larger size is a plus, when using the K5 without a grip, my pinky does not rest on the lower part of the body grip, this is not the case with the D7100. With the K5 I need a battery grip attached for my average size [glove size medium] hand in order for my pinky to rest comfortably, with the D7100 I do not need the battery grip for this.
- Flash Features
Well, again, really don't need to explain much here, there are nearly as many different flash specific features on here as there are total features on the K5 (maybe not that many, but a whole hell-uv-a lot of features that are flash specific). Also, the availability of premium flashguns and flash accessories is just mind boggling.
- Premium Glass Selection
No comparison, from primes to telephotos, oem to third party glass, there is quality premium glass everywhere for Nikon mount.
- Tethering
Need no explanation here.
- Dual Card Slots
Great feature, and programmable also - you can choose to make one card to hold your raws and the other to hold jpegs, or you can use one as a backup.
- Metering
Metering is extremely impressive, I have yet to clip highlights and my curves seem to be really consistent - the D7100's metering system is definately a big step up from the K5.
- AF Adjustments
You can set values at [+/-]20, you can also set different values for a lens and TC combo, another really nice feature.
- LCD
The LCD on the D7100 is bigger and brighter.
- VF Display
The VF display in the D7100 is twice as bright (if not more) than the display in the K5. MY K5 Pro's VS D7100
- Construction
The K5 feels a little more solid and more dense, this is probably due to the smaller size and more magnesium alloy being used in the K5's construction.
- Memory Buffer Size
The buffer size is quite a bit better.
- TAV Mode
Not available on the D7100, however it can be somewhat mimicked on the D7100 but it is kind of a pain.
I only touched on a few of the features/options that I make use of on the D7100 (and the other references pertaining to glass and accessories), IMHO, the couple of things/features that I noted for the K5 are really the only things that can compete against the D7100. Don't get me wrong, I love the K5, but again for my usage it really can't match the D7100.
