Originally posted by russell2pi Seems a bit dumb to pay for a lens with a large image circle which you're only ever sampling a small fraction of at a time. If you're gonna stitch anyway, why not stick with a lens that just covers your sensor and pivot the whole shebang around the node as in a normal panohead arrangement?
This device allows for a flat stitch, which results in fewer (none?) stitch aberations. With a pano head you have to be constantly aware of keeping the camera level, insuring that it is mounted so it pivots around the nodal point, and worry about optical distortions in creating the stitch.
In a flat stitch, distortions are reduced because you are moving the sensor in a parallel plane to the subject vs. in an arc around it.
The RhinoCam isn't for 360° panos, or spherical panos, it's for creating a much larger flat image with which to make large prints. The two really aren't competing directly with each other, they are complimentary.
As far as using a MF lens vs. a APS-C lens it's the same argument for using a FF lens vs. a APS-C lens- you're in the sweet spot. So why the larger format lens? When you move the lens off-axis you need the larger image circle to cover the sensor at the extremes of shift of the lens (or in this case the body, since the lens doesn't move the body does).
