Originally posted by normhead Note to self... -1.2 stops, batch export....
But wait, there's more!
-1.2 is an arbitrary value chosen by me. -1 should be enough, but I do -1.2 to be safe. Note that this won't help much if you use ISO 100. The native ISO is 200, so you lose one stop of highlight headroom at 100. For scenes with high dynamic range, use bracketing or ISO 200 or maybe both. Or, use the K-5, which is clearly superior in this department.
Set
Sharpness to -2, all the way to the left, and handle your sharpening elsewhere. SPP's sharpening can be a little harsh, even at the default setting.
You may have noticed that you can save these settings, and you might think that doing so would save all of the things you've done to a particular photo. It doesn't. It only saves everything in the
Tonal Adjustments section. Nothing else (noise reduction, color mode, white balance, etc.) can be saved and transferred between pictures.
I turn down SPP's noise reduction, too. I put color (chroma) noise at 25%, luminance at 0% (Lightroom handles that part better), and I leave banding at the default of 50%, since I don't believe Lightroom has a tool to handle it. To do this on all your photos, select all of them in the library view (ctrl + A), click the
Edit menu, and select
Noise Reduction, the second choice from the bottom. The settings you choose there will apply to all of the photos you have selected.
I don't know if anyone else has this problem, but SPP randomly eats my picture's EXIF data on export. If I do a batch, somewhere between a half and a quarter of the pictures come out without any metadata. I gotta figure out how to fix that, because it's a
huge pain to delete all these misfires, export them again, and repeat the process until they all have EXIF data.
