Ok.
Finally got a chance to do this and hope the results will be useful to everyone.
Managed to borrow a Ricoh GW3 wide angle converter for the GR to test our on the DP1m.
This is a converter than converts the 28mm to 21mm eq for the Ricoh GR and by most reports, a very good WA converter.
Ironically, the GW3 is 49mm thread and the GR needs an adapter for it.
On the Dp1m, it just screws on.
So here are the results.
W/o WA converter
Sample 1 -No GW3 | Flickr - Photo Sharing!
with WA converter
Sample 2 -with GW3 | Flickr - Photo Sharing!
Pls go to the original full sized samples to have a detailed look.
As some of you know from my other reviews, I'm pretty lazy to do 100% cut outs and making sure they are rightly sized on flicker to prevent excessive compression and all that.
Just hate doing those sort of things...
Personally, I'm at a dilemma because of what it gives and what it takes away.
1. Much wider with the GW3 .
2. IQ in the center and for the most part the 75% of the frame, is not degraded that badly and can be recovered with a bit stronger sharpening (low sharpening settings by bayer filter standards actually). The usual DP1m shot needs none to a 25% str, 0.1 radius for my taste. With the GW3, perhaps it needs 50%; 0.2-0.4
3. There is vignetting on the corners. Not a big problem if there is nothing on the bottom corners (eg. roads/ trees/bush). Easily touched up if its sky.
4. Edges are actually ok. Only the corners are bad
5. Corner IQ drops off rapidly. Again, may be ok if the part of the photo at the corners are 'mushy' stuff like the sea, water, beach sand, bushes/grass (maybe). Can be a real disaster if its buildings like in this case.
It can be rectified a bit with careful cloning work for some photos, but hard to count on it.
I'd think that the composition of a photo using the GW3 on the DP1m will have to take into account the poor corners,
Either leaving important stuff out of them, or composing with the idea of cropping out the corners.
So mixed feelings.
It opens up possibilities with the wider angle on a small kit.
But corner IQ is bad.
Its about $300, and imo, for the pros/cons, it would be an easier decision to buy if it was nearer $230
At this point, I think I will wait for a used one on my local forum.
