Originally posted by ivoire Maybe shorten freestyle tripoding to "freepoding".
I like it! We should start a freepod club.
Originally posted by barondla Scratchpaddy, you called the SD1 your "patience" cam and the DP as your "everyday cam". Do you consider the SD1 harder to shoot than the DP?
I said that because the SD1 competes with my K-5 IIs. If I need something quick, I grab the K-5. If I can go slower, the SD1 comes. The DP2 might come, too, just because it's so small. It's in a category by itself.
I use the two Sigmas in completely different ways, so it's hard to say which is easier. The DP's have no viewfinder, and most everything is set from the QS menu; everything revolves around the screen. The SD's have no live view, and almost everything has a dedicated button or dial; I could get along just fine without the screen at all. The sensor's the same, but that's where the similarities end. The DP is a little quicker to clear the buffer, too.
Oh, about that picture you took: snow or not, that looks darn cold!
And kudos to you for using a
real tripod.
