Originally posted by Rob01 The only remaining thing I dislike is lack of bulb mode or a longer exposure time in the DPs. I am perplexed as to why this is not updated through firmware... overheating or battery problems?
It's not much better on the SD1. There is a bulb mode, but it cuts off at two minutes, with no way to override it. I'm assuming it's a noise thing, and maybe heat, as you say. I've done 30-second exposures, and they're noisy even at ISO 100. I stick to my K-5 IIs for nighttime. During the blood moon this past week, my Sigma gear stayed home.
I agree with Panoguy, you should get a DP. They'll give you the best the Foveon has to offer, resolution-wise. Plus, the SD1M, coupled with any lens worth using on it, is very big.
Originally posted by panoguy (I have the 18-35mm f/1.8 now - damn you scratchpaddy!)
Ha ha! Resistance is futile!
And you got a 180mm macro too?
I had my eye on that lens for a while, but I don't shoot telephoto or macro enough to justify it.
I took the 18-35 and 12-24 on a 15-mile hike about a month ago, and I only took out the 12mm once. I'm starting to like it more and more. I took the DP2M as well, and I actually liked the colors from the SD1M better. I always have trouble working with the colors from this sensor, so the closer I can get out-of-camera, the better. I know it's the same sensor, but almost everything I get from the DP2M comes out too green, while the SD1M comes out purplish, but closer to how I like it. Here are some of the pictures from that hike, clickable for full-res, as always:
23mm f/1.8
18mm f/5.6
35mm f/2.2
DP2M, f/5.6
There's no reason for me to get the 35mm Art, since I have this zoom, but that new 50mm...
