Originally posted by Class A Currently I guess that the AF base equivalent of Canon's MPAF may not be that large because the photodiodes are probably not that discriminating in terms of angular sensitivity. However, this will probably be addressed when MPAF uses 16 photodiodes, or so, in place of one conventional sensel.
Over at DPR, somebody now pointed me at a second Canon patent originally filed Dec 2011 in Japan but available as US patent. It treats the algorithmic problems and how to switch between contrast maximization and phase minimization. They call it sum or difference signal. It is a rather simplistic view at the problem. If Canon really does it that way, they are not exploiting their own invention's potential. A better approach would be to combine both approaches and to use (2D auto- and cross-) correlation functions rather than (1D) summation and difference filters. And to drive the sensor in varying modes (sparse, windowed etc.) to obtain an optimum signal at max. speed for a given phase within the still photo AF operation (target selection, focus, precision focus, stopped-down focus).
This is the patent:
http://patentimages.storage.googleapis.com/pdfs/US20130147998.pdf
BTW, it doesn't seem to quote the original JP patent I found in the Japanese web. So, Canon did not file it in the US. Rather interesting. Maybe, they didn't want to make it too obvious what it is based upon.
Yes, Fuji's idea (as used by Hybrid-AF and MPAF) has a low angular sensitivity (although it can be large with fast lenses -- Canon in the patent even speaks of problems in this case to determine shift between then differently shaped signals, another hint at a simplistic approach). The low angular sensitivity can be offset by a high precision correlation function between the partial images which turns even small differences into a solid signal. My multi pixel idea (quad pixel) does not increase the angular sensitivity. But it solves the ambiguity problem where the cross correlation maximization has no clear single solution (either because of missing texture or too large a parallax error). It is the cross type AF sensor analog. More than 4 pixels most probably won't help, although it could at least in the case of very wide apertures.
