Originally posted by Rondec I don't really buy that. The difference in dynamic range is a couple of stops. Plus, the D800 does better, both in low iso and high iso situations. Comparing the 5D Mk II to the 5D Mk III sensor, you see minimal improvements from one to the other. An improved high iso score by a quarter of a stop and that's it. The big improvements in the 5D Mk III are supposed to be in the autofocus department, not the sensor.
When I'm talking about the "pro" cameras I'm referring to the 1DX and D4. Both of which have been optimized for higher ISO work at the expense of lower ISO. Sensors don't have variable ISO settings. They only have a base ISO and everything else is image processing.
Even if the S/N ratio is the same for a given APS-C sensor and a FF sensor of similar pixel density, when you enlarge for print the FF sensor will yield better results.
A3+ is 158,907mm^2
D800E sensor size is 864mm^2
K-5IIs sensor size is 370mm^2
To print at A3+ the image from a D800E has to be enlarged 183 times.
To print at A3+ the image from a K-5IIs has to be enlarged 430 times.
If DxO shows the S/N and DR are exactly the same between the two, you will still get much better results from the larger sensor when you go to print simply because you are enlarging the noise in the FF image less.
If you don't see the differences then it is because the monitor you did post processing on, or the printer used for final output was not capable of reproducing those differences. A lot of noise and DR is lost in final print. A monitor is illuminated and can show much more than a print that is simply a reflective media. Most inkjets only offer the equivalent of an EV 7. Professional inkjets can only reproduce maybe the equivalent of 9EV with the right paper and ink.
If someone says they can't see a difference in prints then there are probably several good reasons.
1. The scene did not have a huge DR to begin with.
2. The image was captured in regular 8 bit JPEG.
3. The monitor was a normal 8 bit SVGA display and not capable of displaying the detail and DR of the captured image. If the monitor can't display it then you can't process.
4. The printer/ink/paper combination is not capable of reproducing the color depth or DR that is captured by the sensor.
I picked up some 24" x 36" posters from the printer the other day. They gave me the wrong order. I know the photographer and she uses Canon. I don't know if she is still using the 5DII or if she has upgraded to the 5DIII, but the images looked like mush. I don't know her settings, but I know the Canon 5DII or III is more than capable of delivering better quality that what I saw. She is a typical batch process wedding tog who has been in business for 5-7 years. She copied the LR presets from her old mentor and has never learned to really process images for maximum quality.
