Originally posted by pinholecam I think I will share this here. (did the same in the local forums)
So not all is rosy with the A7.
The sensor reflection issue is perhaps the 'show stopper' to some considering this camera as a smallish, FF system.
this issue has been well documented on multiple forums, and it's not a show stopper by any means... it's only seen under certain extreme conditions, as in, when pointing the camera at the sun, or certain combinations of lens and lights at night... i've never seen it on the a7r.
it's not only the a7, people have also reported it on certain nex cameras, Sigma DP1 and SD15 cameras, the fuji x10(google white orb), and even television cameras, a guy saw sensor reflection on the jimmy fallon show.
the alleged sony response:
Reply from Sony Hong Kong about Problem with Sony A7, reflections on the sensor, this is a "normal optical phenomena, this optical phenomenon also comply with the camera and lens specifications acceptable range"
attached the reply email form Sony Hong Kong
首先感謝閣下購買 Sony 產品!
關於閣下早前的查詢,在日常拍攝中,我們常常都會面對不同的光源,例如是太陽、街燈、閃光燈等等。當相機面對一些強光時,光線從進入鏡頭內之後,它會在鏡頭及相機中反射,而某些強的光線在反射後會在最終影像上形成有色的圓盤,這些照片中的效果,我們稱作「光暈」。基本上,在面對光源下拍攝時都可能出現及十分常見,而光源的強弱,以及使用不同鏡頭、相機組合時,「光暈」的形狀或密度亦會有所不同,影像上形成的「光暈」屬於正常的光學現象。經廠方參考閣下早前所提供的照片後,此光學現象亦符合相機及鏡頭規格的可接受範圍內,請閣下可以放心使用產品!
若閣下需要在面對光源情況下拍攝時,建議您嘗試稍微改變拍攝的角度,此舉可以大大減低照片中出現「光暈」的現象。甚或乎閣下亦可以自行調整拍攝角度,特意為照片增添鏡頭光暈以營造特別的相片效果。
我們十分感謝閣下的意見,希望在未來所推出的攝影器材產品,為廣大的攝影愛好者提供更加優良的攝影產品,謝謝!
如閣下還有其他疑問,歡迎直接回覆本電郵查詢或致電索尼客戶服務熱線 或瀏覽
http://www.sony.com.hk 或
http://www.sony.com.hk/service/
保養及維修事宜 28335129(星期一至星期六 09:00-18:00)
產品查詢及電話銷售 23452966 (香港)/080-0039 (澳門) (星期一至星期日 09:00-20:00)
技術支援 23893202(星期一至星期日 09:00-20:00)
再一次感謝閣下支持Sony產品!
Ted Cheung
客戶服務本部
香港業務拓展總部
索尼香港
Translate by Google
First of all thank you for purchasing Sony products !
Earlier inquiries about you in everyday shooting , we often are faced with different light sources , such as the sun, streetlights , flash and so on. When the camera face some glare , the light from entering the lens after it in the camera lens and reflector , and some strong light colored discs will be formed after reflection on the final image , the effect of these photographs we called " halo ." Basically, are likely to appear in the face of light shooting and very common, and the strength of the light source, and the use of different lenses , the camera portfolio , " halo " shape or density will vary, formed on the image " halo " is a normal optical phenomena . After the factory Photo provided by you earlier , this optical phenomenon also comply with the camera and lens specifications acceptable range, you can rest assured that the use of the product !
If you need to shoot in the face of the light source , it is recommended that you try to slightly change the angle shooting , a move could greatly reduce the photos appear " halo " phenomenon. You also can adjust almost even self- shooting angle , lens flare added specifically for the photos to create a special photo effects.
We are very grateful to your comments , I hope in the future launch of photographic equipment products for the majority of photographers with more quality photographic products , thank you !
If you have additional questions , please feel free to reply to this email or call our customer service hotline or visit the Sony
http://www.sony.com.hk or
Care and maintenance of 28,335,129 ( Monday to Saturday 09:00-18:00 )
Product inquiries and telesales 23452966 ( Hong Kong ) / 080-0039 ( Macau ) ( Mon-Sun 09:00-20:00 )
Technical Support 23893202 ( Monday to Sunday 09:00-20:00 )
Once again, thank you for your support Sony products !
Ted Cheung
Customer Service Division
Hong Kong Marketing Company
Sony Hong Kong
---------- Post added 02-08-2014 at 05:39 PM ----------
Originally posted by pinholecam I know this sort of 'problem found' post will often bring up very defensive remarks or even angry ones. (perhaps not on a Pentax forum??)
So if you have shot in similar situations, and found no problems, do share sample picts.
Even better, if anyone got a solution (eg. bracketed shots and clone out ), thats the best.
Lens no good?
Adapter issues (adapter is matt and rough inside) - may try gaffer tape to eliminate the possibility.
Avoid diffused light sources that shine into the lens? -might be not very agreeable with this combo.
i doubt that it's an adapter issue, and i haven't yet seen a fix for it... maybe try changing the angle of the sensor face, relative to the incoming light, but that could prove to be a real hassle when it comes to framing the shot... lose perfect framing just for this?
i would also wonder if a tilt adapter would change the angle of the incoming light slightly?
