How I setup Clear Image Zoom
1. CIZ -- Clear Image Zoom is a setting in Menu -> Setting (2nd tab) ->Page 3 ->Zoom Setting
default is optical zoom, I have to choose CIZ from the default Optical Zoom
2. I customize the AEL key for Zoom. At shooting, I toggle the switch on AF/MF to AEL. Hit once and choose 1.0x to 2.0x in CIZ setting. In the following sample, I use the setting for 1.2x
I tried out 1.2x in ClearImageZoom that essentially gives my Sigma 30mm f/2.8 ability to remove the noticeable vignette from f/2.8 to f/8.0. I think this will come in handy for people trying out Sigma 30/60 in FF with auto crop mode turned off.
There is one caveat that I don't quite understand with Clear Image Zoom (CIZ) feature, once enabled, the flexible spot AF come back with a big rectangle as if the auto focus can't work on a particular spot but an estimate similar to the green rectangular box in NEX focusing with issue. Do any of you try Clear Image Zoom and run into this focusing handicap. Is this normal, I ran into rectangle box in AF in both my FE 35mm and my Sigma 30mm. I turn to DMF and use MF override to ensure accurate focusing.
with sigma 30mm f/2.8 with baffle removed, shot in f/8, Zoom at 1
same setting with Sigma 30mm f/2.8 in f/8.0, zoom at 1.2x
Of course, there is still slight vignette on the corners. If I shoot in f/2.8 to f/5.6, the 1.2x Clear Image Zoom seem to offset the vignette making the Sigma 30mm f/2.8 work like a Sigma 36mm f/2.8. And remember the Sigma is a $150 lens that I bought and some people probably get it even cheaper.
I like to know what are the caveats, is there loss of quality in CIZ. How is it different than the cropping in post processing? I don't know the detail behind.
Here is a reference shot in f/8.0 shot from Sony FE 35mm f/2.8 ZA for reference
with Sony FE 35mm f/2.8 ZA in f/8.0
View: original size
And why is the flexible spot AF return a rectangle? Will CIZ degrade the AF system? I use DMF to counter the rectangle.
Thanks,
Hin
