Originally posted by ranchy been awhile i came into this thread..
Wow itshimitis, A7RII!!
So how's the camera, compare with its previous model? like the ISO, AF and also image quality or AWB?
AF will still hunt in poor light, more points when you are using a native FE lens. At the moment am disappointed in the long exposure noise when you go beyond a certain amount of time. Where my 645Z will not grumble too much and leave me tiny hot pixels that are easy to clean up from the shadows, the MKII leaves much larger ones that are much more difficult to clean up. Even where you use Long exposure NR, you will see more noise than I'm used to on a particularly long exposure. Below 4 mins is fine with LENR but too much above that and things get hairy. So Sony has some work to do on a firmware update.
Much has been made of the 11+7 lossy raw, and I'd like to see 14 bit lossless compressed raw, but I'd rather the long exposure noise was treated first. The lower and lossy bits can exhibit themselves in blue skies if you underexpose, but I do see this sometimes with the 645Z too on 14 bit. The mkII is a little more susceptible to this, so care is needed in processing.
The quieter shutter is great and the new EVF is definitely an improvement. The 5 axis IBIS really helps, I have steady hands so I am often able to handhold at 1/15 at 35mm but the IBIS really helps with consistency.
