Originally posted by 6BQ5 Can it also be assumed that with focus peaking and manual lenses that there is no focus confirmation for when the chosen/configured focus point is considered in focus?
Yes, probably. Unless the A3000 does things differently than other NEX, normally when focus peaking is enabled and you are using a manual focus lens, you can't choose a specific camera AF point to work as the focus confirm target, so the camera won't, for example, 'beep' to confirm focus at any point.
As you manually focus the lens, you simply see the focus peaking coloured 'halo' creep around the contrasty edges of whatever is on the display as you shift focus. It's up to you to decide if you have obtained the focus you want by observing the halo.
The camera can help you manual focus in several ways alongside focus peaking. For example the NEX have an option for 'MF Assist' during manual focus which will enlarge a portion of the image for a specified time whenever you adjust focus, to help you more precisely get things in focus.
FWIW, a handbook and manual for the camera are
downloadable from Sony USA
