12-15-2013, 10:16 PM   #1
Nikon D200 as starter camera?
I have been thinking about trying out Nikon because of the affordable & high quality lenses: Nikkor 35mm f/1.8 DX, Nikkor 50mm f/1.8 AF-D and the Tamron 70-300 VC USD.
[I am really disgusted with Ricoh and their Pentax 50mm f/1.8 DA solution having a plastic mount--let alone no quick shift--at a ridicuously high price of $200... Nikon 50mm f/1.8 AF-D is metal mount screw drive for only $120. For $200 you can get a Nikkor 50mm f/1.8 with metal mount AND quick shift.]
I was about to order a Nikon D7000 because they are $699 now, NEW at B&H but I've been reading tons of complaints about this camera's back focusing issue. So I decided I don't want it.
I think I now want to wait a few years until the D610 comes down in price (under $800) then get it, but for now I need a DSLR body I can grow a Nikon lens collection with, and I've been thinking about the D200 because it's so affordable used (under $250).
It's a quality made camera from what I hear and takes all the Nikon Lenses AI, AI-S, AF-D, AF-S, etc..
What do you think? Should I go for it? I don't need video recording and I can deal with less megapixels and lesser image quality than my k-x.
12-15-2013, 11:01 PM   #2
I would not get the D200. Way too old. Though the old CCD sensors were great at base ISO, the CCD sensors are miles ahead in low light performance.
I would choose the D7000 over the D200 any day.
Beware though, if you are planning to upgrade to FF (D610) at some point, make sure your lenses are compatible. I don't believe the 35mm f/1.8 you mentioned will work on FF.
Also, are you sure the 50mm AF-D has full time manual (quick shift)? I thought that was the internal motor lenses like the 50mm AF-S G, but I am not sure.
By the way, I love nice build quality, but I have never heard of a plastic mount failing. I have a plastic mount Canon 50mm f/1.8, and it has lasted through rough use for years.
12-15-2013, 11:14 PM   #3
There is a much better camera for the same price here on the forums.
Pentax K-20D
It will also take almost every M42 lens ever made and almost all of these are metal mounts.
I own a Nikon D300 but bought a Pentax K-10D so that I could use my M42 mount lenses as well as all the Pentax A,M and K mounts - all metal BTW
My Nikon is a good camera 12Mp but the D200 is only 10Mp. The Pentax K20D is 14.6Mp.
Look, I know megapixels aren't everything, but this is a no contest between the D200 and the weather sealed K-20D
The K-20D also has image stabilisation built into the camera and not the lenses - so you get it with whatever lens you use.
Have a look at the K-20D
OH
12-16-2013, 12:05 AM   #4
QuoteOriginally posted by Oldhand Quote
Pentax K-20D
OH
I already have a K-X, and I don't think I am going to get rid of it. I'll use it for my pentax glass and m42's. But I want to be able to use Nikon glass as well so I need a Nikon body. D7000 have back focusing issues so I don't know of another affordable Nikon camera to get that takes AF-D lenses and AI and AI-S etc..
12-16-2013, 12:25 AM   #5
QuoteOriginally posted by geekette Quote
OK, I understand I do have both, after all
Be aware that pre-AI Nikon lenses are problematic and can cause damage to D200 D300 D7000 etc.
You will need AI or AI-s minimum if you want to avoid those problems.
OH
12-17-2013, 08:08 PM   #6
cali92rs's Avatar
I would take a used D7000 any day of the week before the D200. That camera shares the same stellar sensor as the K-5, will take screw drive lenses, and that back focusing issue was overblown like 95% of camera "problems" on the internet.
12-17-2013, 08:35 PM   #7
lguckert79's Avatar
If I was you I would save up and get a D700 FF
12-18-2013, 12:15 PM   #8
Pick up a Canon 5D, the original, not the mkii or iii. $500 - $600 used and the $99 50f/1.8. IQ will beat the crop bodies up to around 3200 iso and you don't have the funky Nikon skin tones to fix.
12-18-2013, 11:46 PM   #9
KungPOW's Avatar
QuoteOriginally posted by RyanW Quote
If you only have 200-250 to spend on a Nikon body, then the n D200 is a fine camera.
It has beter Auto focus, better metering, and better on camera flash than a K10D. I have owned both.
When using any Nikon with Lightroom, you get better skin tones and colours if you use a camera preset when you import the files. Otherwise the colours will look flat.
Above ISO 800 the K10D has better noise control.
12-20-2013, 07:21 AM   #10
Banned
You could get the new 20mp Sony A3000 for $299 w/free shipping from B&H with the 18-55mm OSS lens that is light years better than the D200 and works with any DSLR lens made using low cost adapters .
Sony A3000 vs Nikon D4 @ 1600 iso
12-21-2013, 01:44 AM   #11
Well I got my Nikon D200 in the mail the other day. I paid $200 for it. The seller said it had a 24k shutter count but it turned out to be 64k--seller gave me a partial refund of $65 (which was very generous); so I got this once $1695 camera for $135 Plus $20 shipping.
Bought an AF-S 35mm 1.8 lens from Best Buy that evening and took some portraits of my nieces.
QuoteOriginally posted by KungPOW Quote
I did notice this. I had the color set to normal and there wasn't enough saturation in iPhoto--I had to add some in. I will try the "vivid" color preset on the D200 for next time.
Here is a slightly cropped portrait I took with this camera & lens. I did no processing except for adding a tiny amount of saturation.
I also picked up a $109 AF-D 50mm 1.8 from B&H, which I can't wait to try out
12-24-2013, 07:26 PM   #12
reeftool's Avatar
I think you got a good deal. I bought my daughter a used D200 a couple of years ago. She still loves it. You can't go wrong at that price. I personally prefer my K10D and K5 to the Nikon but some of that is that I'm just so familiar with them. I have used the Nikon with good results and if you use flash a lot, the Nikon has much better options.
af-d, d200, d200 as starter, f/1.8, nikkor, nikon, nikon d200, quality
Using the $200 Nikon 1 V1 as a 4K video camera ploetzlich Canon, Nikon, Sony, and Other Camera Brands 2 03-19-2013 04:56 PM
Pentax K10D vs Nikon D200 karq Pentax DSLR Discussion 14 02-01-2009 03:34 AM
K100D as a starter camera? Javaslinger Pentax DSLR Discussion 16 01-18-2009 03:34 PM
Nikon D200 vs Pentax K10D codiac2600 Pentax DSLR Discussion 5 05-03-2007 08:47 AM
All times are GMT -7. The time now is 11:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
