01-13-2014, 12:09 PM   #1
Wired's Avatar
Full-frame standard budget zoom F mount?
I'm in a pickle... I only have primes for my D800 kit and I'm going to be shooting for a biking magazine article this weekend and realize that a 28-70mm zoom could probably be the most useful item in my kit. However I'm changing jobs right now and very very limited on funds, $500 is kind of the budget which rules out the Tamron 24-70 f2.8 VC that I want to fill this role.
I essentially have the option of the 28-85 f3.5-4.5 from Nikon, or the 28-75mm f2.8 from Tamron. Both are similar in price.
Can anyone compare the two for me and tell me which one is better in terms of AF speed, sharpness, contrast?
Thanks
If worse comes to worse I will use my K5/K3 combo with the DA*16-50 and DA10-17 fisheye. However I'm sure the DA*16-50 AF will not keep up with cyclist.
would also look at an UWA zoom if its possible in the budget and I would use my 50mm otherwise.
01-13-2014, 12:54 PM   #2
Perhaps you can rent a lens?
01-13-2014, 01:10 PM   #3
Wired's Avatar
No credit card.
I do that on purpose so I don't get into trouble...
01-13-2014, 05:09 PM   #4
Wired's Avatar
Anyone use the 18-35 3.5-4.5 from Nikon? The new version?
01-14-2014, 06:21 AM   #5
I can't give you an objective comparison as I've never used the Nikon lens, but I've had a used 28-75 Tammy (screw drive w/aperture ring) for almost two years now with my D700 and, generally speaking, see no reason to upgrade/update unless it fails.
Hopefully someone can tell you how it holds up on a higher res sensor.
af, budget, da*16-50, f2.8, kit, tamron
Current K-mount Full-Frame Lenses ElJamoquio Pentax SLR Lens Discussion 100 02-20-2016 02:22 PM
From Full-Frame Sony... to Pentax... to Full-Frame Canon Mr_Canuck Canon, Nikon, Sony, and Other Camera Brands 42 01-21-2014 12:50 AM
Full Frame Fisheye Zoom F and 43 Limited on K5D (Sample Photos) RiceHigh Pentax SLR Lens Discussion 7 10-09-2008 10:48 PM
All times are GMT -7. The time now is 07:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
