Originally posted by mrNewt I doubt there will be any issues with the EV dial.
If is anything like the MX-1 EV dial (which is on the edge as well), I don't think it will switch/move when putting it in or removing it from the bag
Did I said already that I really like this thing? Too bad it costs so much...
Originally posted by tuco Why when I just said my XP1 would get inadvertently changed? If you stow it in a tight area in a camera bag, for example, the friction can rotate it when you pull it out because it is not offset from the body. And I would tend to forget about looking at that dial because I didn't change it much.
No need to be so aggressive about it... as you can see on my previous comment, I was comparing it with the MX-1 dial (the new camera... not the old one).
Never had an issue with it and I am using it pretty much every day.
Also, as a personal opinion (no need to get defensive about it either), I always thought that if the bag you are using is so thigh that buttons, dials, switches gets moved out of place while using it, then maybe you need a bigger bag
