01-31-2014, 05:18 PM   #1
Christine Tham's Avatar
Hot tip for those who use the A7 and A7r with adapted lenses - Lens compensation
Here's a hot tip that even the Sony product managers didn't know about and not mentioned in the manual.
Buy the lens compensation app:
https://www.playmemoriescameraapps.com/portal/usbdetail.php?eid=IS9104-NPIA09014_00-000008
Basically this app will allow you to create profiles for adapted lenses. For each lens you use, do a test shot in the app and it will automatically determine some of the correction parameters. You can also manually adjust the parameters.
Me (and everyone else I know) basically ignored it because we thought it only worked on JPEGs. So this is the hot tip: IT ALSO WORKS ON RAW FILES!!!
Basically it writes the correction parameters into the raw file and Lightroom (or another program) will apply the corrections when opening the raw file.
Things it can correct:
  • Peripheral Shading: Corrects brightness and the intensity of reds and blues around the edges of images
  • Chromatic Aberration: Corrects red and blue lateral aberration
  • Distortion: Corrects barrel and pincushion distortion
Note: this includes colour casting issues and vignetting on some lenses.
Best of all, once you buy the app - it will also work on older NEX (NEX6 for example). Once you purchase the app, you can download it for free for additional devices (up to ten).
02-03-2014, 06:25 PM   #2
That's interesting. Does it slow the camera down by much? Do you need to make a setting for all the focal length & shutter combinations?
02-04-2014, 01:58 PM   #3
QuoteOriginally posted by Thingo Quote
I dunno - I don't use it myself as I have created Adobe Lens Profiles for all my lenses, but those who are using it haven't noticed a significant impact,
It is certainly a lot easier to use than the Adobe lens profile creator. And it does colour casting correction.
At a minimum you need to generate a profile for each lens - the instructions seem to imply you can create profiles at different aperture stops (eg. 2.8, 4, 5.6, 8 etc.).
a7 and a7r, app, compensation, correction, distortion, lens, lenses, parameters, tip
A7 A7r with K and M42 lenses Post Images here Sliver-Surfer Canon, Nikon, Sony, and Other Camera Brands 110 12-10-2014 01:11 PM
What We’re Finding Wrong With the Sony A7 and A7r So Far interested_observer Canon, Nikon, Sony, and Other Camera Brands 104 05-12-2014 10:43 AM
First Zeiss Sonnar FE F4 24 to 70mm Lens Review for the Sony A7/A7R jogiba Canon, Nikon, Sony, and Other Camera Brands 5 01-25-2014 09:11 PM
Sony 24MP and 36MP A7 /A7r first look and pre-order today ! jogiba Canon, Nikon, Sony, and Other Camera Brands 83 11-23-2013 07:07 PM
First full size images of the A7 and A7r cameras with lenses! jogiba Canon, Nikon, Sony, and Other Camera Brands 50 10-15-2013 11:42 PM
All times are GMT -7. The time now is 12:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
