Originally posted by Cannikin If you want a portable 1080p camera that is great at low light, this is one of the better choices.
perhaps i need to sum up the crop comparisons between the two cameras once again?
a7s: 1.1x focal crop when shooting video
gh4: 2.3x focal crop when shooting video
that huge cropping loss totally limits the low-light capability of any sensor... i suspect that the light gathering ability of a 2.3x equivalent lens is going to be less than that of a full-frame lens, which is why people resort to things like speed boosters.
Originally posted by Cannikin There are a lot more things important to videography than just low light noise... not really a serious selling point to discerning videographers.
fyi, people who do this for a living(clearly not you) don't want the gh4, they want the sony fdr-ax100 4k camera... to give you an idea of the interest level for that cam, there is an 85-page thread for it at dvinfo.net:
"CES 2014: Sony FDR-AX100 Consumer Cam $2,000
I had a feeling Sony would release a lower end 4K consumer cam. Didn't expect this one.
1" CMOS sensor and XAVC-S only upto 4K 30P.
12X zoom lens
Built in ND-filters
720p/120fps
$2,000 and etc.
Sony FDR-AX100 at DVinfo.net Originally posted by Cannikin And just for reference, a scene with f/1.4, 1/50s shutter speed and ISO 3200 is about EV 1-2. A typical night street scene is EV ~4-8 depending on traffic/lighting density, and a shot of people lit by a decent size campfire is about EV 5. Reference:
Ultimate Exposure Computer the gh4 has marginal iso performance, and there are audio issues... it's a nice toy, but still only a toy.
"...Audio appears to be fairly decent, with one exception: there’s very low-level electronic noise present, at least with most third-party microphones. Crank the headphones to maximum, and you can hear a buzz like a motorboat, varying with shutter speed and with assorted camera operations.
In most real-world recording (at least, everything I’ve tried so far), the buzz is swamped by ambient audio, but in a recording studio environment it could be an issue.
The buzz has its own webpage, the full conversation is on dvxuser, and a discussion with Panasonic is on Facebook.
...Noise builds up gradually to ISO 1600, then gets blotchier at 3200 and downright obstreperous at ISO 6400; ISO 6400 pix look more like impressionistic paintings than movie frames. Trailing artifacts aren’t noticeable at ISOs below 3200; at 3200 they’re present but mostly harmless; at 6400 it’s a special effect, like the output from a Vidicon tube camera. Color holds up fairly well, but the shadows go noticeably purple at ISO 6400.
QHD or 4K, seen as QHD or 4K, will show similar characteristics.
FHD, and QHD downsized to 1920 x 1080, look considerably cleaner – mushing pixels together boosts signal more than noise. Also bear in mind that Cine D shows more shadow noise than other looks; using STD or NAT instead of Cine D, I can at least double ISO before I’ll see the same level of noise as I do in Cine D. (In fairness, Cine D is intended as a “flat” look for later grading; one should boost the contrast and crush the shadows a bit, whereas I was looking at it as it was shot.)
I’ll happily shoot up to ISO 800 or 1600 in FHD or QHD for HD delivery. 3200 is OK for emergencies, but I’d reserve 6400 for a Vidicon-emulation look (in monochrome, it’s quite convincing)."
Review: Panasonic DMC-GH4 Micro Four Thirds HD/4K Camera at DV Info Net
