I bought the Pentax Q for extreme telephoto and extreme macro, with mitigate success, but then the photographer might be the issue. Still working on that.
The question that came up was where do I have issues, well clearly the Pentax Q is for clear daylight only.
My prosumer DSLR goes a lot further on high ISO (I find most at ISO1600 usable), but does what an APS-C can do (at this moment, still waiting to be surprised with A7S like APS-C sensors).
To go up on ISO performance we would indeed be taking flagship Canon, Nikon or Sony cameras. DXO Mark has clear results, but I also believe that is not all:
Originally posted by Fogel70 Is this some sort of competition?
IMO there are many better cameras than A7r, but A7s looks to have the lowest noise on out of camera extreme high ISO jpgs.
But with similar NR processing on RAW data from other camera, the end result might not be very different.
There is clearly a competition and if the Sony A7s would not have scored 3702 ISO, I would not be looking at it.
For comparison: if it matters to have a D610 iso a D700 Nikon for ISO performance then it matters to have the A7s compared to anything else.
It all depends on what
you want to do.
Clearly there are AF considerations in wildlife, but there will always be compromises.
I'm looking for taking pictures in light situations where AF does not work since the contrast is too low, when taking pictures at ISO 25k (I really do that) I'm on manual focus, and I'm never going for fast action (well I do, but I do not expect it to work).
jpg does not matter to me, it will not deliver the result I can get with raw and this is more true when you go to Post Processing (PP).
Less pixels has some influence, but I would rather have a usable A6 (actually A3 is possible) size then a not usable A0. 12mpix is plenty, in the past I used to shoot at 8, which gave a fine results for my purpose, albeit limiting some more.
Now I do believe that DXO Mark uses the sensor data when they can, that is without processing. Even raw files are processed in some way.
So what is the result of the out of camera file is already unclear + what will be the result after PP even more. Some noise is easier to work work away then other.
The sad thing about this conclusion is that it is personal, it depends on shooting style, on PP style and what you want to do with the picture at the end.
So the A7s is not a wildlife shooters dream, mostly they will use a high fps, high ISO performance and super multiple axis tracking AF DSLR which supports all features of the top telephoto lenses. The Sony A7s does not do that. However someone on a budget might be able to complement their system with a Alfa 7S for extreme low light performance.
P.S.: Budget for a minimum high spec wildlife set-up is around 17K€ for me. Second hand manual, DIY gets close to that for 4k€, so I do see some potential for alternative wildlife set-ups with the Sony A7S.
