This topic keeps hunting me, so I have evolved in my conclusion:
I believe we have established that the Sony A7s is a not the wildlife shooters dream, I believe this is a lot closer:
Originally posted by Digitalis I use a Nikon D4s with a Nikkor 400mm f/2.8G VR, using a Nikkor 2X teleconverter ...
Why: AF is better, very close in dynamic range and low light ISO performance and a lot better lens selection.
There are great Pentax alternatives:
Originally posted by rawr But if you have the money, it seems the 654Z just about performs as well as the A7s in low-light, ISO 204,800 and all.
In a tiny bit larger body ...
Honestly it seems that the Pentax 654Z will give a real revolution as well, be it for other applications as the D4s.
And there are better weather sealed Pentax bodies (compared to other brands) that will do great in most of the wildlife situations and let you go out there when others stay in.
Where does this leave the Sony A7s? What are the strengths?
1) Relatively low price. No that body is not cheap, but the sensor performance (sharpness and low ISO) is very high for the price and probably outperforms anything close in price and portability in August 2014.
2) It is small and light. Yes a mirrorless is smaller and lighter then the DSLRs and Midframes. I find myself carrying already too much gear and weight gain is a decision factor when I´m 20m up a climbing path in a forest at the crack of dawn. (e.g. the Pentax Q series is great to take along, it can do a lot for the extra bother of carrying it).
3) Flexibility on lenses. With adaptors (just like the Pentax Mirrorless systems) you can add almost any lens (but losing features), I found some Leica guy stating high liked the result of the A7s with Leica lenses better then the Leica bodies.
So not the wildlife shooters dream, but combined with a good Prosumer action oriented DSLR system, some old very high quality (any brand) lenses and some passion for low light photography, this body can give a nice portable set-up for a wildlife amateur on a (larger but not professional) budget. The pro will take a larger and a lot more expensive system and there are certainly combinations possible with other bodies that give similar possibilities, it is up to the buyer to spend his money wisely.
