Originally posted by Kayaker-J But first and foremost, I wonder if any of you have tried the DA 15 this way?
Curiously, I finally using the DA 15 on my EM-5 this past weekend (I've owned the adapter for over a year and a half). My copy of the DA 15 is just a bit soft wide open, but it sharpens up quite a bit stopped down. Nonetheless, the lens doesn't seem to be quite as magical on the EM-5 as it is on a Pentax DSLR. I'm not sure if it has something to do with the thicker sensor stack of the EM-5 or the fact that the EM-5 is not exactly designed to get the most out of the lens. But while the lens performed decently I wasn't blown away by what I saw. The colors were somewhat different from what I'm used to from the lens. I wasn't seeing those Pentax greens and blues.
Originally posted by seventysixersfan Or should I get this cheaper one that doesn't have an aperture control?
Not if you want to use your DA lenses on the GM1. Incidentally, the DA lenses make more sense on m43 because (1) they're smaller, and (2) they tend to be wider. The DA 15 becomes a solid wide angle choice and the DA 21 becomes a true normal.
Originally posted by seventysixersfan Do I need to buy both if I want to use both DA and FA primes on my micro-4/3 camera body?
No. Just ignore the aperture control dial (i.e., keep it wide open) when using FA primes.
