07-23-2014, 04:55 AM   #31
Hi jcdoss and Tessar,
Thank you so much for your input. I have updated compatibility list at first post of the thread.
Cheers!
08-29-2014, 08:11 PM   #32
FotoPete's Avatar
Haven't had time to really shoot with mine since I've got it but I have the EF-Nex LT II and so far the 8-Element Tak 50/1.4 (w/ M42-EF) hits the lens turbo element at about 1-2m. Blue spot seems to be mostly gone from the LT gen 1
Problem with the EF-Nex is that my PK-EF and M42-EF adapters fit rather loosely on my EF-Nex Turbo II. I'm thinking I shoulda just ordered a native PK Lens Turbo II instead.
08-29-2014, 10:29 PM   #33
QuoteOriginally posted by FotoPete Quote
So you have been using an additional lens adapter on top of the Lens Turbo, and then you mount a lens on top of those two? The scope for optical misalignment, light leaks etc seems pretty high. I'd go for just the native LTII.
09-28-2014, 10:59 PM   #34
Photonz's Avatar
Hey chaosteo!
Do you have some more Ricoh 55mm F/1.2 on LT II examples? I have to plan my upgrade path and have a Revue Revuenon 55mm f1.2 which I think is an identical lens to your Ricoh (7 elements, 6 groups), and I'm entertaining the choice between a K-01 (advantage sensor stabilization) or a Sony NEX 3/6 + Lens Turbo II (advantage, FF perspective).
Secondly, since you've had four more months to try out your adaptor, what is your latest opinion on it?
Jasvox, those are some really great photos!! What is your opinion on shooting at fast apertures on the LT II?
Also, has anyone tried out a M42 lens on a LT II PK via m42 to PK adaptor? I have the Takumar 55mm f1.8 and Takumar 50mm f1.4 which I would also like to use on the PK Lens Turbo II if I do go this upgrade path...
11-07-2014, 08:55 AM   #35
jcdoss's Avatar
I think I'm about done with the Lens Turbo series. Version 1 had the blue dot, which was horrendous when it showed up. Version 2 has apparently moved the lens elements closer to the distal lens mount, so now wide lenses won't focus to infinity without bumping glass. Shimming worked (I had to add another two layers since my last post to completely fix the problem I had with the M20/4), however now I lose infinity focus with other lenses (M50/1.4). There's just too much hassle with the whole setup, so I think I'll be interested in selling. I've still got both versions, so anyone interested, please PM me with an offer.
I think my ultimate solution for full frame will be to get an A7R. Or a Pentax, should one ever show up and bear the right features, but that's another issue.
11-08-2014, 02:35 AM   #36
Photonz's Avatar
Meh, that is very sorry to hear that it's not a winning combo.
Full frame Pentax (which will have to be more expensive than Mirrorless FF is for the foreseeable time out of my budget ($500). Thus I guess I'll have to make peace with apsc and settle with a K50, or I could go for a old Cannon 5D classic with a shaved mirror and matte focussing screen... 12MP is more than most would ever need.
If only Metabones would attempt a PK speed booster...
11-08-2014, 10:05 AM   #37
Bukaj's Avatar
Revuenon and Porst 55 F1.2 tested on the LT II. Both work, infinity hit around 10m. If you focus past it, the rear element hits the glass inside the LT II...
02-05-2015, 06:27 AM   #38
The lens turbo version II, is much improved on the original. I have yet to notice any aberrations or sharpness issues as tested with the SMC Pentax-M 50mm f1.4 and SMC Pentax-M 35mm f2.
07-05-2016, 01:20 AM   #39
QuoteOriginally posted by jcdoss Quote
Tessar, try the double-layer of electrical tape shim method and see if that fixes the problem you're having with your M28.
https://www.pentaxforums.com/forums/76-non-pentax-cameras-canon-nikon-etc/263...ml#post2873806
I have both the K & M versikns of the Pentax SMC 28mm f3.5. I intend to use them with the Lens Turbo II focal reducer on a Sony A6000 (E mount). You wrote that shimming the adapter to avoid the rear lens element to bump the lens adapter could be a solution. How did you do it? Did you test the Pentax K 28mm 3.5 too? Thanks
07-08-2016, 02:25 PM   #40
jcdoss's Avatar
QuoteOriginally posted by Hector G Quote
...You wrote that shimming the adapter to avoid the rear lens element to bump the lens adapter could be a solution. How did you do it? Did you test the Pentax K 28mm 3.5 too? Thanks
Sorry for the delay.
I removed the rear lens mount on the adapter (three little screws) and put several layers of electrical tape below where the adapter fits, then re-mounted the lens mount. You can't add too many layers since the screws are really short. It didn't work with the M20 (one of my favorite lenses) and that's why I gave up. I don't have a K28, so can't speak for that lens.
10-30-2016, 10:40 PM - 1 Like   #41
I am still using my NEX F3 + Lens Turbo II and think that I can add a few lens to compatible / incompatible list.
Working:
K28/3.5 shift - very useful!
FA28-70/4 - it is a nice light setup
FA28-105/4-5.6 Powerzoom
A50/1.2
A24-50/4
Problematic:
K28/3.5 - cannot focus to infinity due to rear lens hitting the front element of LT II.
Sigma 24/2.8 Superwide II - this one is strange as it seems that the locking pin of the LT cannot fit into the corresponding recess of the lens.
For all the lenses that work, the center resolution is always very good - sharp and detailed. I cannot comment on the quality of the corners. I can only say that they are all acceptable. I do not think that any of them show very bad corners compared to the typical corners that I see on my APS-C bodies.
apsc, body, equivalent, fa, ii, lens, lens turbo, lens turbo ii, nex-6, turbo, turbo ii pk-nex, ur, viewfinder, weight
New Lens Turbo II generation now available for Pentax lense LFLee Non-Pentax Cameras: Canon, Nikon, etc. 8 06-03-2014 01:33 AM
Lens Turbo, NEX, and DA lenses jcdoss Non-Pentax Cameras: Canon, Nikon, etc. 6 03-18-2014 07:09 PM
Sony Nex Turbo Lens Booster Gear Porn Sliver-Surfer Non-Pentax Cameras: Canon, Nikon, etc. 23 10-19-2013 06:16 PM
Lens turbo PK-NEX tripod collar jv.pentax Non-Pentax Cameras: Canon, Nikon, etc. 4 10-05-2013 04:23 AM
Sigma 50mm EX DG HSM F1.4 Lens First Impression mcjm78 Pentax SLR Lens Discussion 22 08-29-2009 04:59 AM
All times are GMT -7. The time now is 11:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
