10-24-2014, 04:25 AM   #16
VisualDarkness's Avatar
No automation but with a manual aperture control. It's well made though.
11-13-2014, 08:48 PM   #17
dosdan's Avatar
This page is very recent, so I don't think it's been publicly mentioned yet:
NX1 Smart Camera, 28.2 MP, 3 Super AMOLED Touch - Samsung UK
Be sure to click on all the "Next" and "+" to see the full info.
Firmware v1.01 is dated 10th Nov 2014.
The camera looks like it will be marketed as a class-leading APS-C model.
Also a link to the 50-150/F2.8 S ED OIS zoom lens:
http://www.samsung.com/uk/consumer/smart-camera-camcorder/lenses/zoom-lenses/EX-ZS50150ABEP
Dan.
11-13-2014, 08:54 PM   #18
It looks like a canon camera with Samsung labeled on it
11-13-2014, 10:16 PM   #19
QuoteOriginally posted by dosdan Quote
Priced accordingly too: pre-order price AUD $1867 (body only) at Digital Camera Warehouse Australia (get a free battery grip!) The 16-50 f2 - 2.8 zoom is $1398 and the 50-150 is $1730. Ouch. Cheapest NX prime is a 30mm f2 pancake for $429 ...
The NX1 body is still cheaper than the 'pro' Canon 7D II though, by almost $500.
11-14-2014, 09:35 AM   #20
osv
QuoteOriginally posted by Doundounba Quote
I don't need AF either, but I really prefer to focus with the lens wide-open and have the aperture stop-down only when I hit the shutter.
the only reason that you have to stop-down is because you are using an optical viewfinder.
the nx1 has an oled evf, so it should have a wysiwyg display, which means that what you see in the evf is what you'll see in the photo... evf displays turn up the gain to compensate for poor lighting and dark aperture choices, which makes them far superior for manual focusing with old glass.
samsung is saying the screen in back is a Super AMOLED w/Touch Screen, which is what smartphones use... it could be better than the lcd displays that most cameras have, in bright light?
11-17-2014, 03:47 PM   #21
Samsung to drop NX1 prices in January (preorders lower than expected). | Mirrorless Rumors
11-17-2014, 04:40 PM   #22
In looking at the NX-1 specs as they trickle out, the NX-1 AF sensitivity is -4 to 20 EV. Not coincidentally, the same as competitors like the Panasonic GH-4 and Sony A7s.
Exposure metering is still only 0-18 EV though for the NX-1. I often wonder about the utility of being able to AF down as low as -4 EV, but the camera not being able to effectively meter the scene.
QuoteOriginally posted by Winder Quote
Interesting. Even before it hits the stores, they are dropping prices just on the basis of pre-order volumes? Seems premature.
For a brand that few DSLR shooters have experience with, with no complete reviews out there yet, with product details only trickling out, and of course no product in store for people to handle yet, you would expect that pre-orders would be weak.
If I was a likely NX-1 shooter though, it sounds like great news.
11-17-2014, 05:28 PM   #23
I think people want to wait for the reviews to see if performance lives up to the hype. Samsung doesn't have the reputation needed among photographers in the $1,500 price category. Like Sony, Samsung really needs to focus on glass to get the attention of higher end photographers. They have some real gems right now, but just not enough of them. Fuji seems to be the only one getting it right.
Being able to AF down to -4Ev really only has value to people using strobes since they will set everything, including white balance, manually. -4EV is something like a 2 minute exposure at ISO 100 - F/2.8. So unless you are using a strobe its not very practical.
11-17-2014, 05:48 PM - 1 Like   #24
dosdan's Avatar
Here's the first review: https://www.mastercard.com/global/currencyconversion/index.html
Edit: Wrong link. Try this one: Samsung NX1 Digital Camera Review - Reviewed.com Cameras
Dan.
11-17-2014, 06:02 PM   #25
When did Mastercard start doing camera reviews?
11-17-2014, 06:03 PM   #26
I don't like that reviewer. He always gives very bad reviews.
11-17-2014, 06:06 PM   #27
dosdan's Avatar
Sorry, try this link:
Dan
11-17-2014, 06:17 PM   #28
QuoteOriginally posted by osv Quote
The only reason to focus manually at a stopped down taking aperture
would be if you're just stopping down one or two stops on a fast lens with focus shift.
Otherwise, the focus will be much less accurate.
11-18-2014, 02:35 PM   #29
osv
QuoteOriginally posted by lytrytyr Quote
when you shoot at the same aperture that you focused at, it's the ultimate in accuracy, because focus shift is eliminated.
a dslr with ovf can't do that in lower light conditions, the aperture has to be opened up in order to see, as Doundounba outlined above.
i don't know if that is 100% applicable to mirrorless cameras in low-light conditions, using autofocus, because i don't use autofocus.
i have seen really bad focus shift in legacy 50mm primes, going from f/1.4 to the next stop up... but it's not nearly as bad when the focusing happens above wide open.
---------- Post added 11-18-2014 at 01:41 PM ----------
he's not the sharpest tool in the shed his advice to transcode to h.264 as an intermediate codec, in order to edit nx1 video, was something that only a noob would say.
11-18-2014, 03:25 PM   #30
Actually, this is not correct, and I never use a viewfinder. I shoot using a K-01, which has neither an EVF nor an OVF.
We were discussing the possible use of adapted Pentax lenses on the NX1. I was pointing out that the Samsung P/K to NX adapter has no linkages between the body and lens, and so you will be shooting with the lens stopped down. There is no other choice. For regular usage, this might not pose too much of an issue, but for macro it's a bigger problem.
Yes, the K-01 does the same with its LCD too, but there is a limit. When I do have to stop down prior to shooting - like when I use a reversed lens on extension tubes - let me tell you that at F/16 (or higher), unless your subject is in direct and very strong sunlight, you pretty much don't see a thing in the LCD and it's impossible to even find the critter you're trying to shoot. (This would be true with an OVF as well - even worse!) This problem - as well as focus precision in order to nail focus on the eyes - is why I prefer to shoot with a macro lens that is linked to the body and that only stops down when I hit the shutter. That means either a native system lens or a lens from a system for which there exist "smart adapters" for your body. An example of this is micro four thirds cameras and four thirds lenses. With the proper adapter you can, for example, mount a four-third Sigma 105mm macro onto a m4/3 body and get in-body aperture control (and even AF, in this particular case).
So, for the Samsung NX system, the only macro lens for which you get in-body aperture control and wide-open focusing with automatic iris closure to appropriate F-stop when the shutter is hit is the native Samsung 60mm F/2.8 macro. I'm sure it's a wonderful lens, but it's pretty short. I'd like at least a 90mm. On K-mount, I can pick from at least 5-6 different 90-105mm 1:1 macros, and also some longer 150mm-200mm full-on 1:1 macros. For a macro shooter, that's a wonderful system to be in, and the only mirrorless system so far to come close is m4/3, where you get a native 60mm macro (FoV equivalent to an 80mm lens on APS-C) and can use 4/3s macro lenses.
Certainly for me, the NX1 looks like the most appealing body out there right now, and I can't wait to see some reviews. But as macro is my main thing, switching seems a little... impractical.
85mm, aperture, autofocus, camera, conditions, dxo, focus, lens, lenses, performance, samsung, sensors, shift, stuff, system
Samsung NX1 BSI Sensor Winder Canon, Nikon, Sony, and Other Camera Brands 27 10-22-2014 11:40 PM
Samsung NX1 on sale Tom777 Canon, Nikon, Sony, and Other Camera Brands 2 10-07-2014 02:57 PM
Samsung NX1 should of been a Pentax JohnBee Canon, Nikon, Sony, and Other Camera Brands 28 09-26-2014 09:24 AM
Just looked at the price of the new Samsung NX1 kit VoiceOfReason Canon, Nikon, Sony, and Other Camera Brands 10 09-19-2014 08:05 AM
New 28mp APS-C Samsung NX1 shoots 15fps and 4K video ! jogiba Canon, Nikon, Sony, and Other Camera Brands 6 09-05-2014 10:16 PM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
