[edit]
Argh sorry I was completely mistaken: I thought A-mount = sony alpha...
No, I meant an adapter for sony A7. My bad, sorry for the confusion.
[/edit]
Hello,
what is a good adapter for M42 screw mount takumars, specifically the SMC Takumar 1:1.4/50 8 elements version and the SMC Takumar 1:1.8/55 for sony FF cameras?
So far I have found online the Novoflex at about 100 € and a bunch of others, but not all their description are clear about required or not required modification concerning the fitting of the lens' rear pin, if any or no filing is required on the adapters.
Any suggestion?
Also, I have a C/Y planar too, is it more economic, to buy a c/Y to A-mount adapter or adapt both M42 and C/Y to some other adapter, like Pentax K and from there to the camera?
I'm a bit puzzled at the moment.
Thank you!
