Originally posted by Clavius But in computers the warm liquid is always transported to a cooling fan
*ahem* the coolant is transported to a radiator, which is cooled by a fan. Iarger fans can run at lower RPM which reduces noise and vibrations, also larger copper finned radiators are more efficient. Some Phase one digital backs have cooling fans - however these cameras for obvious reasons aren't recommended to be operated during inclement weather.
It would be possible to use a peltier heat pump connected to a metal like silver which could be used as an external surface on the camera - Silver transmits heat and is able to release it with a higher efficiency than copper or gold, however such a solution will likely be expensive - and add to the weight of a camera
Originally posted by Clavius Same goes for peltier cooling. The heat could be transported to the outer body of the camera though
Though peltier effect cooling is a power consuming process - and you have to be able to dump all the heat somewhere.
Originally posted by Clavius Rumors on SAR now are that Sony is supplying the sensors for that new Canon 5Ds 50mp camera
I'll believe that when I see it.
