02-02-2015, 01:14 AM   #1
Clavius's Avatar
Even more dynamic range is on the way...
Sony is working on a new type of sensor with even MORE light sensitivity. Presumably, the new sensor actually count each and every photon that hits it:
Sony makes Photon Counting Pixel sensor. | sonyalpharumors
Sony has a new idea to improve the image quality at very low light conditions. They propose a new tech that actually counts every single photo hitting the sensor:
since a pixel signal is extremely weak when weak light is detected, it is desirable to reflect electrons generated from photoelectric conversion on intensity of the pixel signal while losing as few electrons as possible. In general, however, when electrons generated in a photodiode are transferred to a floating diffusion, carriers (electrons) are doped at an interface level generated due to a defect present on a gate oxide film interface (interface defect) of a transfer transistor.
there is provided an image sensor including pixels each configured to include a transfer transistor configured as an embedded channel type MOS transistor and to output a pixel signal based on a charge transferred to a floating diffusion from a photodiode by the transfer transistor in an on state, and a determination unit configured to convert the output pixel signal to a digital value, then compare the converted digital value to a threshold value, and thereby make a binary determination on presence or absence of incidence of a photon on the pixel that has generated the pixel signal. Accordingly, the image sensor that makes a binary determination on presence or absence of incidence of a photon on a pixel exhibits the effect of reducing influence of an interface state on the transfer transistor.
I don't understand much of this. Understanding "more light sensitivity" is enough for me though.
02-02-2015, 01:26 AM   #2
Of course it does! Everyone know that..... Pfft...!
Q: How do they know they're recording every photon??
I mean, first they have to have counted them to know how many they need to count in order to know they have counted them all.....
02-02-2015, 01:43 AM   #3
Clavius's Avatar
QuoteOriginally posted by Steve.Ledger Quote
For me, the entire explanation of the technology behind it, has the following applicable:
"Any sufficiently advanced technology is indistinguishable from magic." - Arthur C. Clarke
If it's a good advance, then it's all good. I stopped caring about how it works.
02-02-2015, 01:52 AM   #4
bossa's Avatar
Sounds like a real digital process - could be good.
02-02-2015, 02:35 AM   #5
delegopa's Avatar
Interesting, this could enchance low light capabilities. The noise in the results should be very low as well. But there are still three analog to digital conversions. Wonder if they still need variable sensitivity (~ISO) for the initial capture, as the energy of a single photon is mainly defined by the wavelength when in the same enviroment.
02-02-2015, 03:38 AM   #6
QuoteOriginally posted by Clavius Quote
I don't understand
Don't need to.
When you can take a shot at ISO 50000 with the same amount of noise you are now getting at ISO 400 then you will "understand" all you need to.
Until that time I'm not going to take it too seriously.
But I can't think of a greater single improvement to a light box, which is all a camera is, than it's sensitivity to light.
Time will tell.
02-02-2015, 08:19 AM   #7
All I read was it improves low light sensitivity. And nothing about improved dynamic range. Most here only seem to care about noise at high ISO and perhaps forget they are only capturing a pathetic 6 stops of light or so at these high ISOs. I want more DR and better tonal scale at high ISO.
02-02-2015, 08:33 AM   #8
normhead's Avatar
Sounds like marketing hype to me... show us what it means in terms of performance in an actual camera.... then we can evaluate it. Is this meaningful or is it like the advantage of the A7s compared to the a7, which turned out to be about a half stop, and less dynamic range... it seems the announcements always sound earth shattering, and products are minor improvements. IN fact a Sony A7s is rated by DxO 4 points better than a K-5 a number many concede is not distinguishable. SO, while many point out it's a good low light camera, it's definitely not as good a good light camera. High ISO performance so far is couple with less Dynamic Range unless you're talking 645z. Sony doesn't even dress this issue in their literature....
or to be less technical... does the new sensor increase low light performance by clipping the high end, as the A7s would seem to do?
02-02-2015, 09:00 AM   #9
Rupert's Avatar
Not sure what this will mean, if it will mean much of anything? However, the fact that some are working hard to bring better sensors to us is always good news. We've come a long way in a short time, knowing more is to come is exciting to me!
Regards!
02-02-2015, 09:02 AM   #10
QuoteOriginally posted by wildman Quote
Don't need to.
Time will tell.
We are at the point where improvements are incremental, rather than revolutionary. You aren't going to see even a stop improvement in SNR or dynamic range from one generation of a sensor to the next. I don't even know how many more stops there are to get? Hard to say, but certainly there is a quantum efficiency that we can't get past.
02-02-2015, 09:12 AM   #11
normhead's Avatar
MY guess is we carry different camera bodies, like we used to carry different rolls of film, based on the high dynamic range and low ISO performance. Looking for Dynamic range in slow sensors, and low noise levels in poor light in the "s" sensors. We used to have different film backs, that could have different films in them. At some point, perhaps there will be different sensor backs. It used to be that the best high ISO camera, could also be the best DR range camera, or the best high definition camera, just by changing film. So far, DSLRs haven't caught up.
02-02-2015, 11:39 AM   #12
We are at the point where improvements are incremental, rather than revolutionary. You aren't going to see even a stop improvement in SNR or dynamic range from one generation of a sensor to the next. I don't even know how many more stops there are to get? Hard to say, but certainly there is a quantum efficiency that we can get past.
I agree completely.
You would be hard pressed to find any camera of any format that would give me a two stop advantage over my ancient K5.
electrons, interface, light, photon, pixel, sensor, sony, transfer, transistor, value
I feel the dynamic range in video from k-5 is very limited liukaitc Video and Pentax HDSLRs 4 12-29-2011 07:00 AM
The Effect of Lens Flare/Glare on Dynamic Range dosdan Photographic Technique 5 10-15-2011 10:25 AM
Anyone using the Expanded Dynamic Range feature on your K5? mccamp82 Pentax K-5 & K-5 II 16 02-17-2011 03:31 PM
Dynamic Range on the K-x Shahmatt Pentax DSLR Discussion 33 04-22-2010 03:51 PM
For Benjikan- will Pentax give us more dynamic range? button Pentax DSLR Discussion 16 07-11-2007 12:22 PM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
