02-11-2015, 10:21 PM   #1
Replacing Lens Mount on a D700
I want to replace the lens mount on the D700. The previous owner was obviously not careful at all about changing lenses and he did so frequently. It has significant scratching and even a small bend on the extreme outer edge, where the surface has raised up slightly. In a roundabout way, I found out that several bayonets will fit the same camera. For instance, the D200 mount will fit the D700. The D200, D300, D700, D3X all supposedly share the exact same part. I just wanted to know if there is anything in particular one should know about changing the mount. It looks very simple. Also, should the screws be torqued to a certain spec? How important is this? Thanks in advance!
https://www.facebook.com/atiimjones
change, d200, d700, lens, mount, nikon, repair
Whats the crop factor for a 6x7 lens on a APS-C K-mount camera? 2her0ck Troubleshooting and Beginner Help 8 06-16-2013 11:45 AM
Advice on using a screw mount lens with a pin on a K5 montreal.eric Pentax SLR Lens Discussion 15 10-10-2012 10:41 PM
Looks like D800 may have almost a stop on D700 jsherman999 Non-Pentax Cameras: Canon, Nikon, etc. 32 03-27-2012 06:42 AM
Advice on Replacing the Lens Mount on a DSLR? Julie Pentax DSLR Discussion 16 02-23-2012 10:02 PM
Suggestions on how to change a mount on a lens? pentaxk1000denver Pentax SLR Lens Discussion 17 02-10-2012 04:03 PM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
