02-17-2021, 10:10 PM   #2506
QuoteOriginally posted by pepperberry farm Quote
if I understand the process properly, that is all that makes an X-sensor different: the filter array....
There is something about that x filter though, I wonder why itís not on the medium format , too.
---------- Post added 02-18-21 at 12:11 AM ----------
QuoteOriginally posted by boriscleto Quote
As I understand it a X-Trans sensor is just a Sony sensor with Fuji's X-Trans 6x6 filter array instead of the Bayer 2x2 filter array.
I see, thanks.
02-17-2021, 11:57 PM   #2507
Bayer is most popular,Xtrans had an advantage a while ago.
As the tech advances it may not be such an advantage now.Fuji has Bayer in their entry level and 645 size sensors.
Todays news about the delay to the K3/3 is disappointing.I really wanted to see what Ricoh have done with the BSI 26,new processor plus new accelerator.Now its another unknown wait![COLOR="Silver"]
The principle behind Xtrans
https://www.fujirumors.com/fujifilm-x-trans-vs-bayer-pros-and-cons-of-going-...-trans-sensor/
02-18-2021, 02:09 AM   #2508
Jonathan Mac's Avatar
Yes, they just take a standard sensor and use the X-trans colour filter instead of the standard Bayer one. I'm pretty certain the sensors in my K-3 and X-T20 are the same bar the colour filter. TBH I'm not convinced that x-trans improves image quality, after all, I haven't seen any IQ complaints regarding the X-T200 or the MF cameras. Some people seem to think that it has a negative effect though I suspect that they just don't like the limitations on software imposed by the difference. I've nothing against x-trans as I've been nothing but impressed by the IQ from my Fujifilm cameras, though I strongly suspect the wonderful jpeg engine is responsible for that far more than x-trans is.
Here are a couple from the X-T20 and Viltrox 23/1.4. I'm running out, or some might say I ran out some time ago, of photographic opportunities offered in the children's playgrounds close to home, but that's about as far as I go with a camera at the moment.
Taped
by Jonathan MacDonald, on Flickr
Bridge
02-18-2021, 04:56 AM   #2509
amateur dirt farmer
pepperberry farm's Avatar
QuoteOriginally posted by Jonathan Mac Quote
the in-camera options (as far as the jpeg engine goes) definitely helps set the Fuji bodies apart - the jpeg engine in my K-bodies is good, but not nearly as flexible as the X-bodies.....
02-18-2021, 05:04 AM   #2510
That looks like a wicked combo from the photos you've showcased with it.
Apparently Viltrox are cobbling together a 24mm f/1.8 for Sony which I'm quite curious about...
02-18-2021, 05:18 AM - 2 Likes   #2511
amateur dirt farmer
X-H1 with EBC Fujinon Macro 55mm f3.5
02-18-2021, 05:19 AM - 3 Likes   #2512
amateur dirt farmer
X-T2 with TT Artisan 35mm f1.4
02-18-2021, 07:03 AM - 1 Like   #2513
eddie1960's Avatar
this is correct and the reason the medium format isn't using that array rather than the Bayer it does use is down to processing power (and I am sure economies of scale )
Sony makes sensors for many companies but does it to the companies specifications and tweaks. early on in a new level of sensor tech, they will hold it for their own release but not for a long time just long enough to assert their dominance in the tech . Panasonic is also pretty big in the business and make Leica's sensors (via STMicroelectronics a division they are the majority shareholder in) Fujitsu and Toshiba are also big in semiconductor tech.
02-18-2021, 07:13 AM - 3 Likes   #2514
nikkor 45/ 2.8 GN, x-t1
the thing about manual focusing is ... i miss a lot of shots not in focus,, this one i sharpened, but i hate doing that.
is auto focus any better, really though. i get frustrated with auto focus more than with manual
---------- Post added 02-18-21 at 09:18 AM ----------
QuoteOriginally posted by eddie1960 Quote
i doubt i will ever 'get' all the tech .... i wonder when something else will supersede these sensors. a whole new way of recording light ?
02-18-2021, 07:36 AM - 1 Like   #2515
eddie1960's Avatar
QuoteOriginally posted by glinda Quote
Autofocus depends on so many variables. I find my fuji cams much better than the Pentax cams I had...but they are all newer generations. I haven't tried the XT1 recently, though on all my cams i tend to use single spot focus and move it around to what i want only occasionally do I use the other options
the XF23 f2 and XF50 f2 both are snappy solid focus lenses on any of the bodies i have tried them out on . Manual focus is more hit and miss for me since my eyesight is no longer what it was
a focus stack shot lets you select focus, Lytro cameras were the pioneers in that idea and I am sure it is coming to cell phones based on what my current cell can already do.
And the tech really matters less than having the vision for what you want and getting out and shooting it. a friend has an MFA in photography and she is the least tech oriented person i know but has a distinct vision for what she wants (currently she is back at schoold doing a writing-based masters degree too compliment the visual arts one)
02-18-2021, 07:52 AM - 4 Likes   #2516
Jean Poitiers's Avatar
More skate images from late yesterday afternoon. All in front of the Mayor's building. The young woman is Julia and the young man is Thomas. They and the rest of the skate crew have accepted my presence ... in exchange for copies of my images. I gave Thomas a USB key that was loaded yesterday from a previous shoot. All taken with my Fujifilm X-T3 and the XF 35/2 lens. Post-production B&W via Darktable 3.
02-18-2021, 01:10 PM - 5 Likes   #2517
Meyer-Optik Gorlitz 50/ 1.8 , X-t1
02-18-2021, 08:13 PM - 6 Likes   #2518
eddie1960's Avatar
Used the x100t yesterday. Loaded some custom film recipes this was Ektachrome. Added the frame but otherwise no post done
02-18-2021, 08:50 PM   #2519
I marvel at , for instance henri Cartier bresson whom you quote in your posts, to use one camera and lens ......
how many have we all had... and no that long ago started down this road. This camera ,this lens , then this one , now this one .....
02-18-2021, 09:25 PM - 2 Likes   #2520
amateur dirt farmer
X-H1 with TT Artisan 50mm f1.2
14mm, aaron, adapter, bit, camera, christmas, daughter, emphasis, flickr, fog, fuji, jonathan, lens, lenses, love, macdonald, model, nex, outline, people, post, series, settings, shots, silkypix, smith, stephen, system, williams, yesterday
FA 77mm mount on Fuji X-T1 Eagle_Friends Pentax SLR Lens Discussion 5 06-03-2014 08:14 PM
Fuji X-T1 announced twilight_samurai Non-Pentax Cameras: Canon, Nikon, etc. 16 01-31-2014 03:12 AM
For Sale - Sold: Fuji X-20 Black plus extra battery EricBrown Sold Items 2 01-01-2014 05:42 PM
Fuji X-Pro / X-E System Pictures Thread top-quark Non-Pentax Cameras: Canon, Nikon, etc. 16 04-23-2013 02:28 PM
All times are GMT -7. The time now is 05:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
