08-19-2015, 10:11 PM   #1
6BQ5's Avatar
Fuji FP100C development times
I recently purchased a Polaroid 330 Land Camera from the local thrift store and to my joyful surprise the camera works! Now I am trying to figure out the exposure compensation and development times for a metering system that probably shifted out of calibration over time.
What happens if I peel the films apart sooner than the recommended minimum time? Do I get a seemingly over exposed image with poor contrast or is it under exposed with too much contrast?
Thanks!
08-19-2015, 11:57 PM   #2
Painter's Avatar
I believe what you get is over or under development rather than exposure. If memory serves me though under development results in low contrast while over exposure gives high contrast.
08-19-2015, 11:59 PM   #3
MJL
MJL's Avatar
QuoteOriginally posted by 6BQ5 Quote
Are you referring to the Polaroid CdS cell light meter? I find they are very accurate under sunny to shady outdoor conditions - if the CdS cell is working and the lens in front of it is clean. However, like many electronics on old cameras, they may give inconsistent result due to corrosion on the PCB or wiring.
I found the temperature during development is more critical than time in most peel away instant films. It is also better to "overdevelop", i.e. more development time than recommended ( such as 90 seconds at 25C). Underdeveloped prints due to cold temperature (<15C) or short development time will give you a off color/pastel/low contrast pictutre with few details to salvage.
I see you live in Nevada, so I think you should have no problem in using the common 1 minute developement time for FP100C during the day. Anytime when the air temperature drop below 20C, you need to follow the guideline on the film tab rigidly for good result.
08-20-2015, 07:11 AM   #4
6BQ5's Avatar
Thanks for the replies!
So it sounds like there is no pushing/pulling the development. It is what it is. All I can change is the general exposure.
My 330 camera was really dirty. It looked like it sat in the rain. There are trails of rust stains on the outside housing from the hinges. Inside was a little better with just general dirt and grime. I cleaned the lens and the light meter window. The camera is missing the front cover. I rigged up a 3V source from 2 AA batteries, some wire, and alligator clips. Dark scenes gave "slow" shutter speeds, like *click ...... click" while bright scenes gave faster shutter speeds, like "click.click". I can't tell if the shutter or meter is calibrated or not from this. The camera has two film speed settings: 75 and 3000. Fuji FP100C is 100. I figure I would need to adjust my aperture/exposure ring a little toward "Darken" since I have more sensitive film. My first shot was really dark. I turned the ring back the other way toward lighten and the image came out just slightly dark but very nice - very acceptable.
So, something in the camera is a bit off and I'm trying to find ways to compensate for it. I thought I could do something with the development time.
08-20-2015, 08:51 AM   #5
Clicker's Avatar
Not sure if this would help if you didn't already find it?
http://www.cameramanuals.org/polaroid_pdf/polaroid_330.pdf
camera, contrast, development, fuji fp100c development, time, times
Black & White Good Times, Bad Times Bob Harris Post Your Photos! 7 06-22-2014 01:21 PM
For Sale - Sold: LNIB Fuji X10 With Fuji Leather Case 275.00 Robert in Canada Sold Items 2 03-02-2014 04:09 PM
For Sale - Sold: REDUCED Fuji X20 + 2x Fuji batteries + EverReady Case robwill Sold Items 6 02-23-2014 09:12 AM
Fuji 120 film development - where in Toronto Clarkey Film Processing, Scanning, and Darkroom 11 05-30-2012 07:13 AM
From the heyday of the Spotmatic, D-76 development times Nesster Film Processing, Scanning, and Darkroom 1 01-05-2012 03:38 PM
All times are GMT -7. The time now is 09:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
