Originally posted by braver Clackers: well, catchy titles help getting attention....
I don't think their incendiary tone did you any favours with making friends, IMHO.
People will remember you did that to them in the past - it's not a reputation to seek.
Originally posted by braver Corrections -- very interesting! There're corrections indeed conveyed to Lightroom directly, and I'm seeing quite different image character. Wonder if that's due to the flange distance difference.
A+
Wide angles are problematic for mirrorless cameras.
The rear element is so close to the sensor that the angles are oblique at the corners and edges.
You can try to engineer your way out of the problem by:
1. Making lenses as big as DSLR ones (awkward if your marketing department have claimed mirrorless means smaller)
2. Put a layer of microlenses on the sensor stack (makes it thicker, can now smear or discolor corners or introduce artifacts)
3. The poor man's way - RAW file corrections stored as data for a converter to use.
Telephotos can be a problem, too. A mirrorless body is relatively thin, but the most uncorrected 300mm lens would have a 300mm path length from the front element to the sensor.
Btw, I own three MILCs, including FF.
